Old 02-19-2004, 11:12 PM
Kenny Rogers Kenny Rogers is offline
Where is the water leaking in from???
I own a '92 Z24. Yesterday I found a pond under the rear right floor mat. I also found moisture under the carpet in the front. I had the windshield tested for leaks. I notice some moisture in the trunk, but that's common for '92 cav's. How is the moisture getting in?
Ken
Old 02-21-2004, 03:15 PM
Mariano Mariano is offline
Re: Where is the water leaking in from???
Have the seems on your firewall checked. My 91 had the same problem. It was a split seam on the drivers side, it would leak down the door sill and into the rear floorboard. Hop ethis helps.
Old 03-05-2004, 10:06 PM
conanthedestroyer conanthedestroyer is offline
check if it is not coolant.could possiblybe the heater core
Old 03-06-2004, 12:11 AM
thecommi thecommi is offline
Send a message via AIM to thecommi
the sunroofs leak too..... i have 2 90 caviliers z24's and both of them have leaky sunroofs, usually resulting in a puddle of water on the passanger side.
water leaking from under the engine area esr26 Windstar 3 07-22-2006 10:24 AM
Where does the coolant leak from & how to replace fog light Mike_EX Montana/Montana SV6 4 03-28-2005 10:31 PM
94 GC has water leak from the top of my liftgate jeffbeck Grand Cherokee | Grand Cherokee SRT8 5 07-05-2004 12:23 PM
wheres all the water coming from? clyde warren Accord/TSX/Accord Hybrid 1 01-02-2003 01:17 AM
