Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 09-27-2004, 04:11 PM
Mike_EX Mike_EX is offline
Where does the coolant leak from & how to replace fog light
I have been getting occasional coolant leaks showing from my 2000 Montana. The leaks appear to be coming from the rear of the engine, not the front. It only shows up in my slightly uphill driveway. I don't see any leakage on a flat surface except after a long highway trip. Is this the infamous gasket leak problem? or is there a hose in the rear of the engine which might be a bit leaky.
Also, how does one replace the fog lamp. I'd like to have some idea before Crawling under the car and tearing things up. Thanks.
Old 02-15-2005, 04:37 PM
kfazzina kfazzina is offline
When I replaced the foglight, there were 2 screws underneath the shround that covers the light, pull the shroud back, and reach up to the light, twist the light off, then pull the light out by pulling back the tab, and puling the light out, just keep in mind that it is halogen, and use a pair of gloves, surgical or mechanical, so you dont burn the light out.
Old 02-16-2005, 10:24 PM
Hoags's Avatar
Hoags Hoags is offline
Re: Where does the coolant leak from & how to replace fog light
I don't know about your coolant leak but the fog light is changed from the under the van by working by the wheel well. Like Kfazzina says remove the two screws and pull back the plastic shroud. remove the old blub. When replacing the new bulb do not touch the bulb with your fingers the oils from your skin will severly lessen the life of the bulb. Use latex gloves or even a cotton sock over your hand when touching the bulb.
Good luck.
Old 02-18-2005, 01:15 PM
N46460 N46460 is offline
Re: Re: Where does the coolant leak from & how to replace fog light
Good luck.
Look @ posts on this site for intake manifold leak. That would be my bet on the coolant leak.
Old 03-28-2005, 10:31 PM
rubberman rubberman is offline
anyone know the part # for the fog light?
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
