Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 01-02-2002, 09:33 AM
R33gts-t R33gts-t is offline
Send a message via ICQ to R33gts-t
Angry Boost Problems??
My R33gtst seems to be having problems boosting, it never used to when i first got the car about 10 months ago. It seems to boost fine through first gear, then as i shift to 2nd, it only goes to about 2 psi then slowly creeps back. but i run out of revs before it reaches full boost again. This keeps happening through the rest of the gears. I was told that my turbo was stuffed by a mechanic, so i spent heaps of $$$ getting a high flow unit installed. The wastegate was also modified to hold a little more boost, about 9 psi on low I also got a Malpassi rising rate fuel reg installed, but the problem still exists. , I have done ECU resets, diagnostics etc. and everything is fine, also had it checked by a different mechanic as well. So about 3K later, i'm no better off.What the F@#K is wrong with it.
Old 01-02-2002, 03:50 PM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
It sounds like you have a boost leak. It is possible your intercooler or a rubber hose had shit itself. I would start there and work my way around the pluming.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 01-02-2002, 04:33 PM
All the piping to and from the turbo was all checked by the mechanics while the turbo was away being hi-flowed, I've checked the hose clamps etc. several times myself too.
Old 01-13-2002, 05:08 AM
GTRFAN GTRFAN is offline
I am having a similar problem ATM. We think it's a stuck BOV or a hose loose in the BOV's area. Getting the front bar taken off tomorrow so we can get to that area. I it impossible with it on to have a good look and check everything. Will know by Monday night, i'll post what we find.
idle problem? and boost problem... gstclips Off-Topic 3 09-07-2004 12:48 PM
91vr4 boost problem supercoop20 3000GT/Stealth 0 12-04-2003 08:41 PM
1991 mr2 turbo boost problem gdool MR2/MR-S 0 11-29-2003 06:53 PM
93' TT Intermittent Boost Problem pezinicj 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 3 11-27-2003 08:02 PM
Boost Problem NISMO23 General Discussion 6 01-04-2002 10:49 PM
