Go Back   Automotive Forums Car Chat > Cars in General
Old 02-19-2004, 12:34 PM
jgagnon_2020 jgagnon_2020 is offline
How do I remove a decal
Can anyone tell me how to remove a decal I have on my trunk without harming my paint job?
Old 02-19-2004, 09:54 PM
Doug_I Doug_I is offline
Re: How do I remove a decal
This procedure usually will not harm an original factory paint job, so make sure it has not been painted.
2 ways described below
1) Find your nearest auto paint supply store and purchase a decal remover. it looks and feels like those yellowish color erasers. It's a round disk that is attached to a drill, and basically rubs off the decal and glue. It does a good job as long as you keep it moving.
2) Use a heat gun(at a safe distance) a safer way would be using a hair drier. (CAUTION: when heating, the metal under the decal can get to 600 degrees) Heat the decal about 6" at a time. After initially heating for a few minutes very carefully lift the edge, and pull the decal as you heat it. if it gets to hot it will rip let it cool a little and continue. when you get it off, the glue can be removed with wax and grease remover.This will not harm any paint job, unless of course it was painted an hour ago. I use PPG DX330 which can be purchased at an auto parts store that sells auto paint. saturate a rag, and wipe it on, let it set for a minute or two, and the glue should rub right off with finger pressure. some glue comes off with lighter fluid or rubbing alcohol nail polish remover . These will soften the glue.
Old 02-20-2004, 06:35 AM
CraigFL's Avatar
CraigFL CraigFL is offline
For plastic decals, I use a blow dryer and peel. For paper ones, I soak in WD-40 until the glue dissolves and then scrape with a fingernail.
Old 02-20-2004, 11:56 AM
Thanks a million guys.
I'll try with the blow dryer and let you know. Since these are not factory decals I'm hoping they will come off easier.
Old 02-21-2004, 10:00 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Yeah - I'd go with the blow dryer method first since its a free fix.
btw - Nice last name
Resistance Is Futile (If < 1ohm)
Old 02-23-2004, 12:13 PM
I used the blow dryer methode and the decal came off real easy. Almost didn't need the blow dryer
Thanks all!
Old 02-25-2004, 10:58 AM
heathershonda heathershonda is offline
Send a message via Yahoo to heathershonda
Now how about bumper stickers?
how to remove decal residue (mr mark setter/softer) minimin Car Modeling 6 06-10-2009 01:42 PM
removing decal lines whiteracer Exterior | bodykits | Lighting 9 07-08-2005 02:09 PM
How to remove decals AstroRide44 Car Modeling 8 02-23-2005 08:53 AM
problem with Raybrig NSX decals & removing decals sportsfreik3099 Car Modeling 8 01-08-2005 01:11 AM
Removing Decals off of windows Marc-OS Exterior | bodykits | Lighting 4 12-15-2001 05:54 AM
