Old 02-22-2005, 06:20 AM
AstroRide44's Avatar
AstroRide44 AstroRide44 is offline
How to remove decals
I put large body decals on a cuda and then creared it. they cracked like everyone said they would. now how do i remove them with out damaging that paint?
"You can go far with a smile, but you can go farther with a smile and a flamethrower"
Keep it Wingless.....
Old 02-22-2005, 06:22 AM
freakray freakray is offline
AF Modelrater
Re: How to remove decals
If you cleared it, they are in the paint as such. The only way to remove them is to remove the paint, or at least the clear.
Probably the best, and only, way would be to sand them out.
AF User Guidelines
Old 02-22-2005, 10:07 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Masking tape works great when there is no clear, but sometimes the bond of the decal to the paint, or the clear to the paint & decal is weak enough to also rip off with masking tape. This is more likely to happen with urethane and mechanical type bond clears, but you might want to try it anyway, can't hurt it now... - Mark
Old 02-22-2005, 12:19 PM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
Would soaking the decals in hot water work? Like, would the decal adhesive melt & then you could wipe them off? Don't think it'd work over clear tho
Old 02-22-2005, 12:23 PM
Junhao's Avatar
Junhao Junhao is offline
Send a message via ICQ to Junhao Send a message via MSN to Junhao
Re: Re: How to remove decals
Would probably melt the plastic. Not sure though, just a guess.
Home of the Supercars:
Old 02-22-2005, 12:30 PM
i think ill just end up dipping it in CSC for a couple hours, sand it down, and then reprime and paint it... this is a pain in the ass
Old 02-22-2005, 03:18 PM
If tape didn't work, that would be the next thing I'd try, and yes, it is a pain... - Mark
Old 02-23-2005, 08:27 AM
so i tried the masking tape and it worked great, to good actually, it pulled up the decal and the paint. so now i got a silver car and 2 massive spots that are white. so now i got to CSC the rest of the body.
Old 02-23-2005, 08:53 AM
sjelic's Avatar
sjelic sjelic is offline
Welcome to the club, some decals just don't want to peal of, specialy if you used some kind of setting solution.
You tried, this time it didn't work but maybe next time it will
Sasa Jelic
SCALEMAKERS
