Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 06-16-2003, 02:49 PM
whiteracer whiteracer is offline
Send a message via AIM to whiteracer Send a message via Yahoo to whiteracer
removing decal lines
yeah its back up!
So i had a decal on my rear window, and cause it was just getting ugly and too big i took part of it off. Now i have lines of where the decal used to be, how can i get rid of these?
Name's David.
Old 06-16-2003, 06:01 PM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
A product that has worked very well for me in the past is called "Goof off". It is a petroleum based solvent (I believe) and you simply wipe it on the decal lines, and wipe it off, then rinse the applied area with water. Any sort of mild solvent, however, should work, but before using it, try it in an inconspicuos spot (just in case it reacts badly for some reason).
Beer tastes better upside down.
Old 06-16-2003, 10:28 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
actually its "goo gone" get it at walmart or Auto Zone or Lowes. Really works great...
Old 06-16-2003, 10:34 PM
BullShifter's Avatar
00 or 000 steel wool with glass cleaner
followed by
glass polish or chrome/glass polish
Old 06-17-2003, 11:06 AM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
good stuff, I used it too get alotta crap off my car and various other areas...great stuff and only like $3 a bottle
Darrell
thegrumpysergeant.net
Old 06-17-2003, 09:27 PM
Not that it really matters but there is also a product called goof off, although it is the same as goo gone. Just thought I would defend myself, but goo gone works just as well (it is the same stuff).
Old 06-19-2003, 11:55 AM
thomas crown's Avatar
thomas crown thomas crown is offline
Send a message via AIM to thomas crown
for anything on the windows you can also use a flat razorblade, after i use that to scrape a decal off, then use it to clean up all of the sticky stuff too. same with hard to get off bugs, etc. but only on glass, and keep it flat so you don't knick the glass. works well for me.
t.c.
'72 AZ600 Coupe
'86 Accord Lx-i (currently 210,000 miles)
'90 CRX Si
'93 del Sol Si
'95 Accord EX (all show)
'03 Civic EX (45,000+ miles)
Old 06-19-2003, 01:25 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
I've always used RUBBING alcohol for that kind of stuff.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 07-02-2005, 12:01 PM
Underground_Killah's Avatar
Underground_Killah Underground_Killah is offline
Registered User
Re: removing decal lines
acetone works wonders btw
Old 07-08-2005, 02:09 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
A few were already suggested...first suggestion is the above mentioned flat razor blade. If you don't like this, you can use adhesivw remover or 000 stell wool and glass cleaner.
I'd say carefully use the flat razor, it works prefectly. Hold it at a 45 degree angle when you scrap it lightly accross the glass.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
