Old 02-17-2004, 07:35 PM
typerturbo typerturbo is offline
having a clutch problem
ive had a problem i get a bad rattling when starting(stopped) out from 1st gear. when i engage clutch it seems to slip a bit(while rattling) then after clutch is engaged its fine. only does it when starting out when completly stopped. also does it when i go reverse. i have to ride the clutch in order for it not to rattle. it is also hard getting into gear. what could be causing this?
clutch problem..i think bov3220 Engine, Transmission and Drivetrain 4 05-22-2009 12:17 PM
clutch problems, what have I done cg13 S-10 2 11-21-2005 01:43 PM
2000 blazer with 20k miles having clutch problems? macleod1 Blazer 25 01-12-2005 01:25 PM
Having a problem with 77 toyota pickup clutch fountainpen Pick-Up 1 05-26-2004 11:14 PM
having a clutch problem typerturbo Integra 0 02-17-2004 07:37 PM
