Old 02-17-2004, 05:38 PM
rvizi rvizi is offline
Question coolant temperature sensor
Does anyone know if the code P0128 is the coolant temperature sensor? Would this cause the engine to studder and feel like it wants to stall out? Has anyone ever had this problem? Thanks
Old 02-20-2004, 07:16 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: coolant temperature sensor
P0128 coolant temperature below thermostat regulating temperature. this means it's either the thermostat or the cts(coolant temp sensor) i'd change the sensor first and see if that fixes it. this is like driving an old care with the choke on. it will cause drivability issues. make sure you change the right sensor most engines have one for the computer and one for the dash gage
Old 02-21-2004, 07:41 AM
thanks...I'll try that and see if that helps
01 Silverado Coolant Temp Sensor wiring okieguy Silverado 1 08-10-2009 07:39 PM
Coolant Temperature Sensor janellegargarita Intrigue 4 09-27-2004 08:41 PM
coolant temperature sensor 1995oldsaurora Aurora 0 09-27-2004 02:16 PM
Curious about coolant temperature sensor operation westsidex Metro 2 05-26-2004 07:51 PM
HELP!!!!!!! Need Engine Coolant Temperature Sensor and Throttle Sensor LikkleMissLude Engineering/ Technical 3 03-08-2004 02:12 AM
