Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-17-2004, 02:44 PM
Martha Martha is offline
Factory code for keyless entry
Recently I purchased a 2000 Crown Victoria. The owners manual says the preset factory code for the keyless entry system can be found "taped to the computer module". Where would I find this? Thank you.
Old 04-19-2004, 12:00 AM
thepartsyouneed's Avatar
thepartsyouneed thepartsyouneed is offline
Banned
Re: Factory code for keyless entry
These instructions will work on Ford Crown Victoria / Mercury Grand Marquis models 93 94:
Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located behind the glove box. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
These instructions will work on Ford Crown Victoria / Mercury Grand Marquis models 95 96 97:
Enter 5 digit permanent entry code into the keyless entry keypad. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter within 5 seconds of pressing the 1/2 button. Locks will cycle to indicate successful programming. Press any button on 2nd transmitter (up to 4 transmitters total possible) within 5 seconds of previous transmitter. (if the keypad light goes out before all transmitters are programmed, the entire process must be repeated). Press the 7/8 and 9/0 buttons simultaneously on keypad to exit programming mode.
These instructions will work on Ford Crown Victoria / Mercury Grand Marquis models 98 +:
Diagnostic method of programming transmitters:
1. Choose service bay functions from the service function card.
2. Choose DDM (Driver Door Module)
3. Choose Key Fob Programming
4. Press any button on the remote entry transmitter
5. Choose Fob 1, 2, 3, or 4 and press STORE
6. Repeat steps 4 and 5 for additional transmitters
7. Press Cancel to get out of menu
Note: If transmitters do not appear to be working after procedure is complete, disconnect the vehicle battery for 5 minutes, then reconnect and try the transmitter again.
Old 04-29-2004, 04:45 PM
Ford guy Ford guy is offline
Hi Martha,you could find the module call ddm inside the driver door behind the trim or easy your dealer could get the code in almost no time with their computer,they could get the code without removing anything acces ddm module with computer and get the keycode for you.
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 05:46 AM
remote keyless entry problem smity9089 Intrigue 0 04-14-2009 12:45 AM
2000 Taurus Need Code for keyless entry tleeburks Taurus | Taurus Wagon 2 06-29-2007 06:27 PM
How to delete manufactured code set for keyless entry system Escapee2004 Taurus | Taurus Wagon 3 07-12-2004 10:26 PM
How to delete manufacturing set key pad codes for keyless entry system Escapee2004 Caravan | Voyager 1 06-29-2004 08:02 PM
