Old 02-17-2004, 12:36 PM
Igovert500's Avatar
blue + red light magnet
ls6 MAFT?
Ok, a few months ago I was skimming through the old posts on 3si, and I read a few posts about the ls6 MAFT conversion. I have a very vague notion of what this entails. I believe a few members on 3si use it instead of the 83 or 88mm MAS. Does anyone have any info on it, or know a website where I can at least check out the parts. Correct me if I am wrong, but wasn't this not originally intended for use on our cars? Any info would greatly be appreciated. Thanks, Geoff
Old 02-17-2004, 05:14 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
A few memers is a little inacurate. There are tons. You will need a MAF-T ,an ls1 or ls6 MAF, and a filter. Very cheep compaired to the ford equivilant.
Old 02-17-2004, 05:21 PM
Igovert500's Avatar
Re: ls6 MAFT?
I was reading something to the effect that it requires some hotwiring or something. Is it a drop in replacement(w/ the proper adapter) or does it require some fiddling around. Also, I assume (due to the popularity) that it is an improvement over the 83mm MAS w/ K&N FIPK, but how much are we talking here? I am just trying to gather as much info as possible. Thanks
Old 02-17-2004, 06:29 PM
Igovert500's Avatar
Re: ls6 MAFT?
OK, so I did some research, correct me if any of this is wrong. The LS6 MAF is 3.75 inches, so in the low 90mms, the translator allows to tune for various things(including larger injectors). The translator is $200 new and the LS6 MAF is about $130. I guess my only 3 questions that remain are:
1. How does the new MAF fit into the old MAS's place, does it need an adapter
2. What size filter is needed for this
3. Has anybody dyno'd this or have any experience trying it out here?
I'm debating adding it to my mods wishlist, Thanks again ~ Geoff
Old 02-17-2004, 07:21 PM
THe ls6 MAF fits in the place of the stock MAS and requires no cutting, just a little force. The MAFT is a dirrect plug in and requires no wiring.
As far as results, on a compleatly stock car there was a .5 second drop in 1/4 mile time after putting in a MAFT and LS6 MAF. Was running very low 13's after the swap.
Old 02-18-2004, 12:25 PM
Igovert500's Avatar
Re: ls6 MAFT?
Really, that sounds worth it. I've heard the MAFTs can be a bitch to program, but I also saw multiple posts on 3si.org that should help. One last question, what is different about the size, I always assumed it meant a wider MAS or MAF, does it mean longer? A guess a few mm's wider wouldn't be that hard to squeeze in to the stock MAS's spot. Sorry for the continuous questions.
Old 02-19-2004, 04:57 PM
Re: Re: ls6 MAFT?
the different side is the diameter of the MAF, not the lenght. The bigger the diameter the less restriction on the air flow of the engine. Your turbos will spool sooner, and be more free flowing.
Old 02-24-2004, 12:56 PM
Igovert500's Avatar
Re: ls6 MAFT?
If anyone is interested, I found the whole kit on ikonone's sponsor's website
http://www.driven-performance.com/display/206
the ls6 MAF, MAFT, and 9inch K&N filter for $380.
Maft And Maf Problem??? Greg4g63t Off-Topic 7 05-03-2005 11:55 PM
MAFT problems... GrungeAholicVR4 3000GT/Stealth 9 05-03-2005 04:55 PM
GM MAFt and venting the type-S. Exact setup and install procedure? Shpyder Engine, Transmission and Drivetrain 14 04-24-2005 05:54 PM
quality MAFt??? dsmodder Off-Topic 5 05-03-2004 05:21 PM
MAFt/3" gm mas ? mr2mitch Off-Topic 1 11-30-2003 01:18 PM
