SO PISSED OFF!!! I got my Y-pipe like double clamped on in every position! It is a new alluminum Y-pipe with a silicon coupler...the bad thing, it is not flared, i need to do that so it stops blowing off. But!!! the new MAS is pissing me off, I have fixed the Y-pipe blowing off with the clamps for now! But, i lose lots of power at about 3 grand and up, and the car shudders real hard, its slow as hell for some reason, and I have the settings just on the base level for injector size, for the stock injecters, (360cc)...I just need to fix it...I need some tuneing numbers, or specs, or just some damn help...Ive been working on this for a good 4 days now, and im about to just take it to a shop, im sooo mad.
Help, thanks... |
Re: MAFT problems...
i have heard about this problem before. but ussually its on vr-4s with over 18lbs of boost. there is an aftermarket y-pipe that you can but to fix this problem. i saw it on dynamicracing.com
you also might want to check to make sure that you don't have a clogged system or any other kind of restriction after the connection. that would cause too much pressure and pop it off. I had a simaler problem on my snowmobile. turned out there was a mouse nest in it. mice can get into anything.
Fuel cut maybe? What are your settings at? If by base level you mean you have all zeros, then I don't know...wish I had one of these to help..I know alot of people just set all of the numbers to 0, and then fine tune with AFCs. But that's another 500 bucks. Sorry
As far as getting the ends flared, take it to an exhaust shop or something, they can do it real cheap and that will help it stay on better. vr4lover, stock y-pipes blow off at 15psi, not 18.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Yeah, so I was bored and couldn't sleep anyway, so I did some searching. If you are getting a "jolt like your engine just blew up" then you are probably running rich, and over the injectors efficiency = fuel cut. Set all your settings to zero, check your injector settings especially, it may think you have larger injectors right now, and that would account for it trying to pump more fuel than the 360s can handle. Hopefully this will solve all the problems.
Now I'm pissed I got the FIPK rather then the MAFT...lesson to be learned...always explore all options...dammit
this is a good thread for tuning: http://www.3si.org/forum/showthread....3&page=6&pp=10
Re: Re: MAFT problems...
Thanks, Matt |
hey i see u guys know something about maft. i already installed mine and i just dont know how to make it work my gsxt is stock can u tell me how to set the maft. thnx
MY Y pipe wasn't fitting on right so I bought a Dijon tool one for $150, looks real nice and is a sinch to take on and off unlike the old one
. It comes powdercoated to match the color of most 3S cars which is awsome.
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
I saw this and thought...wow I havn't seen Matt on here in close to a year...then I checked the date and realized...
Please don't bring back old threads. If you have questions about the MAFT...start a new thread. In general you want to hook it up, set it according to your injectors and fine tune from there. We don't have any of the specifics of your car, so I can't really say much more than that, unless you start a new thread and tell us more about your specific car, what version MAFT you have, injector size, etc.
