Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 02-16-2004, 06:50 AM
Vacca Vacca is offline
Clutch/Transmission problems...
I have a 1988 Brono II. It's a 4 speed w/ overdrive and I'm not sure of engine size but it's a 6 cylinder. I've been noticing a humming noise when the clutch is not being pressed. I've been told it's the throw out bearing going out, but not really sure as I'm an idiot when it comes to cars. The other day I got in it and it seemed as if the gear shifter was all screwed up... It feels like where neutral is, it's 3rd, it will go into 5th/overdrive and where reverse should be it's 4th gear. It won't go into any other gears at all. Is this the clutch? What would I need to replace to fix this?
I would really appreciate any help on the matter... Thanks...
Old 02-20-2004, 12:55 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Clutch/Transmission problems...
wow i'm confused take it to a shop. i'm not too sure what transmission you have but i'd say the shift lever is loose and popped over one of the shift rods and they are all jammed up now. if you're good at fixing stuff take off the shifter boot and remove the shifter then you'll see whats going on.
Old 03-09-2004, 08:34 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
you have a M5OD transmission. Sounds like the input bearing. The throw out bearing with make a noise when the clutch is pressed in, not when clutch is engaged. The M5OD is not a very reliable trans. Usually the plugs in the top cover will leak or fall out and then run the trans dry. You probably have a 2.9 L v6. The motors are kinda noisy, but last a while.
Old 04-23-2004, 11:45 PM
a5stalker a5stalker is offline
Send a message via AIM to a5stalker
Trans
hey if it turns out you need a new trans i have the same trans with a new clutch i am trying to sell. so if you need it contact me at [email protected]
Clutch/transmission problem cr4a '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 07-06-2006 04:10 PM
clutch/transmission problem opchavez Rodeo | Passport | MU 5 05-02-2005 09:10 PM
1994 Wrangler Clutch / Transmission Problems alexrogo Wrangler 5 10-14-2004 10:16 PM
1998 Cavalier clutch/transmission problem jmccreary Cavalier 1 05-19-2004 12:01 PM
93 Toyota Carrolla clutch/transmission problems wmabern Corolla/Matrix/Voltz 1 02-29-2004 06:56 AM
