Old 02-14-2004, 11:48 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Results of a little torque convert research
I know enough about this to be dangerous. It appears that stall and slip are two different things (I kind of have a hard time understanding this). There are efficient and inefficient ways to to make a higher stall convertor. It appears that the larger diameter the convertor the more inefficient they have to make it to get the stall. The convertor is a viscus coupler. Its trying to transfer power though a non solid connection. The fins of one side of the convertor are acting on the tranny fluid and that fluid then tries to "grab"/ force the other fins to move. Now it pretty much is easy to see that fin angles are going to affect how hard the one side pushes on the fluid and also how easily the fluid can transfer the power to the other set. Now from that you can see that there are efficient and inefficient fin angles. Now you got to start addressing the size of the convertor and the fins. Basically since where not solidly transfering the power we are going through (for lack of better words) some kind of squishy / flexing / twisting / slipping kind of deal. Well if your trying to pass lets say 500 hp through this deal it only makes since that a larger one will do a better job because its physically bigger and can handle the power better. Maybe like tires in mud. Tires with small tread blocks can grab mud but it cant grab enough of it to transfer much power. Now you take a nice set of big old mudder tires with the bigger tread block, its going to be grabbing much more mud and therefore do a much better job of transfering the power. This is where the big convertors down fall comes. It grabs to good so you got to put crappy angles on the fins to get the stall speed up. This same crappy fin angles makes the convertor less efficient and makes it slip. This slipping is a total waste of power. Its converted to heat which takes out your tranny, and slows your car down. Yes it allowed you to build boost quicker but then bit you in the ass the whole rest of the track. Now your smaller diameter convertor can use better fin angles more more efficient power x-fer, but they will still stall because like the smaller tires they can't grab enough. This is the better of the two senerios. You can start running into problems if the convertor is too small because even with good fin angles it just its just too small to try to x-fer that much power through it........
I have too much time on my hands
Andy
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 02-15-2004, 12:59 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Results of a little torque convert research
Andy
Good read, Andy.
But, damn that was a long paragragh
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 02-15-2004, 02:14 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Wow I'm way too drunk to read that..... maybe when I sober up I'll go find that good article on torque converters i read but for now.... Just get me a manaul much easier to understand LoL
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 02-15-2004, 02:22 AM
SkylineUSA's Avatar
If you keep posting GTStang, I am going to have to give you a TWI(Typing While Intoxicated)
Old 02-15-2004, 03:10 AM
thepolishmafia1337 thepolishmafia1337 is offline
good info. now lemme run an idea buy you guys. what if you modified a hydromatic tranny to accecpt a clutch. then you could have as much stall as you wanted and a direct drive while shifting. if you only use the clutch to start out, wouldnt you maximize energy transfer. and imagine when the tranny shifts from first to second. i bet that would tear some compoents up though. i dunno just a thought.
Old 02-15-2004, 03:20 AM
FDTT FDTT is offline
^ I dont think you understand what you just wrote. So you are saying that you would want to put a clutch in place of the converter? Well ther is no shaft or throw out bearing that would work here. Also y not just put a standard tranny in? Would save alot of time rather than figure out how to make a clutch fit into an automatic. LOL
PS An automatic tranny has many clutches, there just in packs inside the tranny.
Old 02-15-2004, 03:26 AM
SkylineUSA's Avatar
Re: Re: Results of a little torque convert research
What???????????? Hydromatic???????????? Clutch???????????
Is there something I am not getting?
Old 02-15-2004, 07:22 AM
hehe your gettin me all wrong. i know exactly what im talkin about. when i said modified, i meant to "modify"!!! you see if you only used the clutch to get the car rolling then used a hydromatic with a manual valve body. it would essentialy do the same thing as a lock up converter. after you got started of course. and it would be a lot harsher shift. it wouldnt be hard to make some sort of coupler shaft to slide over one end and spline into the flywheel. you laugh now but just you wait. "A breakthrough wouldn't be a breakthrough if at some point someone said it couldnt be done"
Old 02-15-2004, 07:43 AM
SkylineUSA's Avatar
Now, I see what your getting at.
Old 02-15-2004, 09:36 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
I've been guilty of that a few times, just ask GTStang about our convo friday night. LOL
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 02-15-2004, 01:00 PM
351wStang's Avatar
351wStang 351wStang is offline
Drinkin beer and talkin cars, only thing left out would be the women.
Old 02-15-2004, 01:31 PM
Hypsi87's Avatar
Good read, Andy.
I'm sorry I was bored yesterday. It was Valint..... er Single Awareness day. So I did that and went out to the grage and drank beer/Worked on car with my other single buddies. After about 30min of that, it turned into just drinkin beer
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 02-15-2004, 09:36 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Re: Re: Re: Results of a little torque convert research
Been there plenty of times. As good of a combo as beer and wrenches sound, for some reason it never really works out well.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-16-2004, 12:06 AM
GTStang's Avatar
Stang Guy
And I was the drunk one... This really don't make much sense.... at that point just goto a direct drive unit like top fuel drag and funny cars use to shifting at all. Very cool shit!
Single awarness day..... lol I'm not sure if I single or not but I batted 2-2 on the Vday day/night doubleheader so I'm pretty good with it this year.
Squealing torque converter Skitzy Express | G Van 4 04-05-2010 01:09 PM
05 tahoe torque converter out. . ??? help bcmagg Tahoe 8 03-22-2010 11:32 AM
Results of torque converter research Hypsi87 Camaro Discussions 4 02-15-2004 02:28 PM
Anyone done torque converter work to their auto tranny? BeaterGinKC Engine 0 11-01-2001 11:32 AM
lock up torque converter bobo_80 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 08-06-2001 08:23 AM
