Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-14-2004, 09:31 PM
gonetobama13 gonetobama13 is offline
Recall Alert, '96-'98 Regals
Hey All,
Just to let you know, I received a recall notice from GM in the mail today. Apparently, some '96 to '98 Regals have a condition where the lower pinion bearing in the power steering gear may separate, resulting in a loss of power steering when making left turns. GM says it will repair the problem for free and also reimburse the owner for any charges incurred if repairs have already been done. The fix takes about 2 hours.
John K.
John K.
Old 02-14-2004, 11:06 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Thanks for the notice. I think ill make it a stiky for awhile
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 02-14-2004, 11:50 PM
SuperFudd SuperFudd is offline
GM also says in some cases the car will turn right when you try to turn left. More typical, left turns may have erratic power asist at slow speeds. Right turns will not be affected so it should not be a problem for us true right wing consevatives. ;>
Don '96 Regal
Old 02-15-2004, 07:41 AM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: Recall Alert, '96-'98 Regals
Don't be worried about this recall! All GM recalls have to pass thur GM legal and the wording changes making it somtimes sound worse than it is. As a GM tech this recall is nothing new we have been doing it on several different carlines. I have changes at least 100 bearings and only seen a handful with bad bearings. Of these bad bearings none of them had a steering problem.
What is happening to this recall is some of the balls in the bearing can fall out of the race and in extreme situtations it can cause a bind in the steering.
Just don't panic the GM lawyers make it sound worse then it is. On the other side of the laywer language we have a recall on something the lawyers call "thermal event" another name for fire.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 04-09-2004, 10:11 AM
Jeromegerald Jeromegerald is offline
Send a message via Yahoo to Jeromegerald
Interesting-i own a buick 1996 regal custom and I have yet to receive a reply from GM concerning this problem. Can you give me an email address to GM so that I can inquire about this problem?
Old 04-09-2004, 11:55 AM
All,
I don't know why GM didn't send the recall notice out to all relevant owners because, besides Buick, it also affects some mid-sized Chevys, Olds' and Pontiacs. I wasn't given a recall number for you to refer to, but call your nearest Mr. Goodwrench and ask about it. As further proof, the recall was even listed in this May's Consumer Reports magazine on page 11. Hope this helps.
John K.
Old 06-05-2004, 09:11 AM
Zedster Zedster is offline
Folks, for those who haven't received the recall notice, here is the contact info from NHTSA's web site:
Make: BUICK
Model: REGAL
Year: 1998
Recall Number: 03V527000
Summary:
CERTAIN PASSENGER VEHICLES HAVE LOWER PINION BEARINGS IN THE POWER RACK AND PINION ASSEMBLY IN WHICH THE RETAINER TABS WERE NOT CRIMPED PROPERLY. THESE RETAINERS COULD FAIL AND PERMIT THE BALL BEARINGS TO ESCAPE.
Consequence:
IF THIS OCCURS, THE PINION SHAFT CAN BE FORCED UPWARD DURING LEFT TURNS AND BACK DOWN AS THE STEERING WHEEL IS MOVED BACK AND TO THE RIGHT. IF THE PINION SHAFT MOVES FURTHER, THE DRIVER WILL NEED TO EXERT MORE EFFORT TO TURN THE STEERING WHEEL, SIMILAR TO A VEHICLE WITHOUT POWER ASSISTED STEERING. IF THE PINION SHAFT MOVES EVEN FURTHER, THE DRIVER WILL REQUIRE MUCH HIGHER EFFORT TO TURN LEFT AND MAY NOT BE ABLE TO TURN THE WHEEL AS MUCH AS INTENDED. WITH THE MAXIMUM PINION SHAFT MOVEMENT, WHICH REQUIRES INTERNAL GEAR COMPONENT DAMAGE, THE DRIVER CAN ENCOUNTER HIGH RESISTANCE TO TURNING LEFT, FOLLOWED BY UNINTENDED POWER ASSIST TO THE RIGHT. IN ANY OF THESE CONDITIONS, A CRASH COULD OCCUR.
Remedy:
DEALERS WILL INSTALL A NEW LOWER PINION BEARING UNLESS INSPECT OF THE EXISTING BEARING INDICATES THAT REPLACEMENT OF THE GEAR ASSEMBLY IS NECESSARY. OWNER NOTIFICATION BEGAN ON FEBRUARY 5, 2004. OWNERS SHOULD CONTACT BUICK AT 1-866-608-8080; CHEVROLET AT 1-800-630-2438; OLDSMOBILE AT 1-800-630-6537; OR PONTIAC AT 1-800-620-7668.
Notes:
GM RECALL NO. 03062. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION?S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Hope this helps!
Old 08-04-2004, 01:38 PM
wet architect wet architect is offline
I have a 1997.5 Regal LS and had the problem fixed a couple amonths ago. My steering was noticeably improved, however it seems to make a knocking noise from time to time on the sharp turns. And as of today, it won't start!
'98 Regal.... no oil pressure after changed oil Mr_D Regal 6 04-06-2010 12:08 AM
Recall Alert!!! Fuel Filters.... cleanshavenrsx Blazer 6 07-07-2006 04:22 PM
Recall? Paint on '98 Rangers? scadaman29325 Ranger | Courier 0 08-11-2004 07:40 AM
Question about brake pads, will pads for '96-'98 fit on a '99-'00 SilverY2KCivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 04-14-2002 01:53 AM
Question about brake pads for 6th gen Civic, will pads for '96-'98 fit a '99-'00? SilverY2KCivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 04-13-2002 06:49 PM
