Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 02-14-2004, 09:23 PM
Adam_Hunsicker's Avatar
Adam_Hunsicker Adam_Hunsicker is offline
Beta Motors
I've been looking for parts for the '03 I4 and keep seeing things for the 01 Beta motor... doesn't the 01 and the 03 I4 use the same motor?
Adam
Black '03 Tib, 2.0, Auto
Old 02-15-2004, 09:34 AM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
Re: Beta Motors
theres plenty of shit out there..
www.newtiburon.com
look around... not teh actual store.. but the boards.......
Old 02-15-2004, 03:33 PM
tibby01 tibby01 is offline
all block components are the same. there are some differences in the head though i believe. and also the fact the beta 1 is MAF and the beta 2 is MAP.
Old 02-16-2004, 03:42 PM
ColeIketani's Avatar
ColeIketani ColeIketani is offline
Send a message via AIM to ColeIketani
Re: Beta Motors
importshark.com, might help as well
2003 Hyundai Tiburon: Injen CAI, Mussa Single Exhaust, Sparco Four Point Harnesses, RRM Front and Rear Strut Bars, 22mm Rear sway bar, Shark Racing Pedals, Painted Rims.
Saving for: Either Big Brake Kit, lines etc, Tien Coilovers Sparco Speed Seat for driver side.
Old 02-29-2004, 12:52 PM
Re: Beta Motors
Thank you... that was exactly the info I was looking for.
Adam
Old 03-14-2004, 10:12 AM
Re: Beta Motors
so the 03 i4 Tib runs on the Beta I?
i'm only making sure, because I'm saving for a supercharger kit
Old 03-14-2004, 01:04 PM
no, the gk I4 engines are all beta II.
Old 03-14-2004, 11:16 PM
Tib Guy
Re: Beta Motors
there are no super chargers for teh i-4's
only turbos or n/a
if you get an i-4 you either... dont care abtou tuning.. or youre planing for a turbo....
Old 03-15-2004, 08:58 PM
Re: Re: Beta Motors
Nisco is right that there isn't a "kit" on the market at the moment however I do know there are some private engineers that can make one for you. I would like to try to steer you away from super though... the only advantage to super vs turbo is that there is no spool up time however you lose hp in order to gain the hp (it takes hp away from the engine in order to turn the super chargers turbine) and spool up time on the kind of small turbo that you'd use on a tiburon is negligible. In other words, Turbo is WAY better for our car.
And nisco... as far as your comment that anybody that got the 4 cyl either doesn't care about tuning or is going turbo.... in about 4 months I will be pushing over 300 bhp through my shitty lil' 4cyl... I'd like to see the aluminum V6 block make that claim and follow through with it.... when I get it there I'll post my dyno and timeslips on here.
Adam
Old 03-16-2004, 11:48 AM
Tib Guy
Re: Beta Motors
hahahahahah
thats so funny
300bhp
and you have an auto i4
youll lose alot in the crank...
youll be pushing maybe 250 or up alil...
a supercharger for teh v6... is up to 247... now over 275 without a public dyno slip....
so your shitty lil i4 is still gonna be shit compared to any one of the superchargers i pick....
ripp mods... highest amount of hp they can go with stock internals...
shooting over 250
nextgenmotorsports.... his cars puttin 275... abd hes shootin for over 300 his car is the test dummy....
so whatver his car puts down so do teh other cars....
alpine stage 2 if it ever comes out....
but id like ot know which company you decide on going with when you get your turbo....
ohh wai t i saw you want gude.....
have fun with that
how many stages they have?.. and what do they intail?
Old 03-16-2004, 11:49 AM
Tib Guy
Re: Beta Motors
ohh and when did i ever say going turbo in 4 months... dont make shit up
Old 03-16-2004, 01:57 PM
Tib Guy
Re: Beta Motors
ok i did a lil searchin around for GUDE stuff and info
and well here it is.. and these are prices...
The retail cost is in black, next to the discounted price available through FLUX Performance, which is shown in RED.
Turbo Kits: $3150 - 2550
Works for MAP based 2.0l Beta II engines.
Includes:
- Chromed Turbo 4-1 Header
- TD04h Turbo (efficient through18psi)
- Intercooler
- J&S Spark Management System (included at the time)
- Chromed & Mandrel Bent Piping
- Modified Hyundai Injectors
- All Clamps and Fittings Necessary for Install
Options:
- Blow Off Valve: $220 - 185
- T3/T4 Turbo: $400 ~ Sorry, he cant discount this option at all.
- Straight Pipe: 180 - 160 ~ This will replace the second cat, and is for off road use only, GUDE accepts no liability for violations of local and state emission laws.
Applications and Info:
Works for 5-speed Tiburon’s and Elantra’s with MAP based engines. As far as an automatic goes, the automatic tranny should be able to hold the 200 HP at 6.5psi without any problems, although, the figures may be lower due to higher percentage of drivetrain loss. If you experience problems though, turn down the boost.
The purchase of an AFC is recommended due to the kit wanting to run rich at altitude, but at sea level it performs awesome. Please be open to ask questions, I will contact him and ask any questions that I don't know the answer to. You may see a dramatic increase in performance and efficiency with the use of a fuel tuner.
Head Kits (Turbo and NA) for I4: Retail: $1650 - $1350
Includes:
Core Deposit: $500 (refunded when old head is sent to GUDE)
- Bored Throttle Body w/ Oversized Butterfly
- Ported Intake Manifold
- Ported & Polished Head
- Racing Valve Grind
- Cam Grinding (Turbo or NA)
- High Compression Radius Chamber (Low Compression for Turbo Application)
OHH AND ADAM... READ THIS!
so have fun with your gude system...
seems to be a waste of money if youre gettin a turbo thatll put less then 200 for you...
im guessin you jus wanna get a turbo so oyu can say you have turbo... instead of actually gettin a good set up
now gude is good their products are quality....
but seems worthless
Old 03-16-2004, 04:31 PM
nisco, automatic trannies are better for dragging. instant shifts.
just get the thing sent off to level 10 for a build up. it will be costly, but worth it. or just swap the tranny out, it shouldnt be to hard.
Old 03-16-2004, 05:38 PM
Tib Guy
Re: Beta Motors
auto trannies are good i know... but you lose power in the drive train!
...thats where all the power gets lost...
so his 3 grand+ system will be absolute crap
Old 03-16-2004, 06:00 PM
the faster shifts would make up for the lost power. and also knowing almost exactly what you will run will help bigtime when bracket racing.
'96 Window Lift Motor - Driver Rear Intuit Park Avenue 0 08-03-2009 02:24 AM
99 passenger window motor/regulator SlimJimRD Windstar 8 07-20-2009 05:44 PM
2000 rear door control box window motor wiring tylerk9 Deville 2 07-18-2009 10:10 AM
Is General Motors - Chevrolet going Bankrupt? Zaara Spark 2 06-01-2009 05:57 AM
350 motor swap bowtieballs2000 Performance 0 03-09-2009 10:26 PM
