Old 02-14-2004, 10:29 AM
Y-Ellow Y-Ellow is offline
Question Fan running on a cold morning?
Is it normal for a fan running right with a start of the engine on a cold (20F, -5C) winter morning?
1991, 4WD, 5.7L Suburban, VIN - K.
Thank you.
Old 02-14-2004, 07:14 PM
GNW GNW is offline
Re: Fan running on a cold morning?
If we are talking about the radiator fan, yes it is. Here is how you can tell if it is working okay. Start up the vehicle and high idle it for about 45 seconds. At about 30 seconds into running, the cooling fan should start to make less noise. This is caused by the fluid in the fan clutch warming up allowing the two fan clutch parts to move seperately. If the fluid were to get too warm it would cause the fan to kick in until the temp comes down again.
Old 02-15-2004, 10:22 AM
Thanks GNW,
that's a relief, becouse I thought there is something wrong with the thermostat.
Thank you.
Town & Country 2006 Cooling Fan running with cold engine. chamuko1967 Caravan | Voyager 4 11-26-2010 02:37 PM
1995 won't start, fan runs as soon as ignition is turned on, engine cold. NScarpi Continental 8 08-09-2009 10:39 PM
Temp guage reads cold and radiator fans running! crowebar Venture 14 03-05-2007 12:33 AM
Radiator Fans running with engine cold smithsr1287 Camaro Discussions 4 01-28-2005 07:53 PM
96 Sunfire running cold, bad fuel economy, Fan always on Snowflake Cavalier Problem Diagnosis 1 01-10-2005 12:38 AM
