Old 10-28-2010, 09:33 PM
chamuko1967 chamuko1967 is offline
Town & Country 2006 Cooling Fan running with cold engine.
Hello; I've got a 2006 Town & Country 3.8 L which the cooling fan is running most of the time even when the engine is cool according to the temperature gauge. Contrary to other cases in this forum when the car is shut down the fan stops working but when the car is on the fan works all the time even when I started in the morning (cool engine)...relay failure ?
Thanks..
chamuko1967
Old 10-28-2010, 09:37 PM
danielsatur danielsatur is offline
Re: Town & Country 2006 Cooling Fan running with cold engine.
You should beable to find another relay in the fuse box to swap with,
else it could be a bad sending unit on your radiator.
Old 10-29-2010, 12:13 PM
jpb53 jpb53 is offline
Here's a wiring diagram. The relay is mounted to the front bumper beam. It is transistorized and use the bumper as a heat sink. You coul pssibly have a problem with the IPM or the wiring in that area.
Old 10-30-2010, 04:50 AM
globaltruckdealer globaltruckdealer is offline
there might be some issue with relay.
Replace the relay then check out the fan. If the problem persist then you have to check out the wiring!
Old 11-26-2010, 02:37 PM
LMP's Avatar
LMP LMP is offline
...mmmin most cars, the fans will start as soon as A/C is turned on, whatever the engine temperature. ANd remember a/C is turned on when DEF or heat/def is chosen too.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
'04 Town & Country...cooling issue mythx Caravan | Voyager 2 03-08-2010 03:57 PM
05 Town & Country Rear AC not cooling 2005tc Caravan | Voyager 5 06-04-2007 10:28 AM
2001 Town & Country cooling fan Relay Scottsarah Caravan | Voyager 3 08-19-2006 08:53 AM
Fuel pump and cooling fan run with key off bugmenot Escort 4 04-24-2005 09:59 PM
