Old 02-13-2004, 09:02 PM
fire31 fire31 is offline
unable to start on first time
I am unable to start my 95 S-10 Blazer on the first crank. One mechanic replaced 2 injectors stating that they were "bad and leaky".
After it has been warmed up, it starts on the first crank. Any ideas as to why the cold starts take a couple of tries? Could it be my fuel pump? If it is, what's an inexpensive way to fix this besides replacing the fuel pump?
Old 02-25-2004, 05:12 PM
georgew georgew is offline
Re: unable to start on first time
try replaceing your oil pressure switch. i just went through this with a local dealer. they replaced the fuel pump($500.00) and still wouldn't start. oil switch did the trick. george
Old 02-26-2004, 09:07 AM
amac209 amac209 is offline
Send a message via MSN to amac209
its a fuel pressure problem. hopefully just the regulator. make sure the fuel pump relay is working if you hear the pump buzz when the key is turned on it's doing it's job
Old 03-02-2004, 06:06 PM
ndsysv ndsysv is offline
on what year\engine was the s10 that you replaced the oil thing
cause my truck is doing the same thing.
Old 03-02-2004, 09:08 PM
all s-10's that are fuel injected use the oil pressure switch to run the fuel pump.
2004 Nissan Sentra sometimes wont start first time when cold echosummit Sentra | 200SX (USDM FWD) 1 11-10-2009 08:45 AM
'99 Blazer hard to start first time after sitting alblogg Blazer 0 07-30-2006 06:13 PM
won't start at the first time when cold harryliuusa Caravan | Voyager 5 12-04-2005 04:04 PM
Unable To Get Timing Right REALLYBIG1 Storm 2 11-04-2005 10:04 PM
Starting engine for first time after parked 2 years CDOJr1961 Engineering/ Technical 3 07-11-2003 08:06 AM
