Go Back   Automotive Forums Car Chat > Geo > Storm
Old 10-18-2004, 08:46 AM
REALLYBIG1 REALLYBIG1 is offline
Unable To Get Timing Right
91 geo storm 4 cyl. non turbo recently did a water pump, put everything back together and cranked it up to get it in time and i cant get tit right on. with i set it so you can drive it. it can't make it up a hill or get over 60 miles an hour. i can't setting to the manurfacture spec either. please help i need to know exactly where the timing marks need to be on the crank and cam shaft.
Old 10-25-2004, 05:16 PM
Lakeshow23 Lakeshow23 is offline
The notches on the camshaft have to line up with each other. Make sure the timing belt is on tightly. If it's on too loose, the car won't have accurate timing at all.
Old 11-04-2005, 10:04 PM
kpree123 kpree123 is offline
Send a message via Yahoo to kpree123
Re: Unable To Get Timing Right
Did you find the answer? I need to get this car running for my son. As a female with limited knowledge I need all the help I can get.
