Old 07-09-2003, 10:23 PM
CDOJr1961 CDOJr1961 is offline
Starting engine for first time after parked 2 years
I just purchased a wrecked '93 Grand Prix with a 3.1 V6. 4000 miles after it had a remanufactured engine installed it was wrecked and has been parked for nearly 2 years. Any tips on what to do before attempting to start it for the first time?
Old 07-10-2003, 12:14 AM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
Just check to make sure everything is fine.
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
Old 07-10-2003, 09:47 PM
darkaccord darkaccord is offline
Send a message via AIM to darkaccord
It will almost definetly run very bad at first. Let it idle for a while, until it runs better, and dont push the engine for about 50 miles.
Also the gas should be replaced, and it couldn't hurt to change the oil.
Old 07-11-2003, 08:06 AM
CraigFL's Avatar
CraigFL CraigFL is offline
I would change the oil and coolant. Remove the plugs and squirt a few drops of oil in each cylinder then spin the engine in short bursts to build up the oil pressure to get the oil flowing before you put the plugs in and actually start it.
'99 Blazer hard to start first time after sitting alblogg Blazer 0 07-30-2006 06:13 PM
"clunks" when brakes applied first time after going in reverse datslegne Windstar 2 09-17-2005 09:29 PM
