Old 02-13-2004, 06:56 PM
barbied barbied is offline
water pump?
Hi - got a 92 Grand Prix that for the last couple of days when I park on a hill would have a low coolant light. Went off when I was level. Today the engine temp went up almost to red and started steaming by the engine block.
I dont see any leaking hoses, but coolant gathering by the block.
Any ideas???
Old 02-13-2004, 07:03 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: water pump?
Bad tstat maybe??
Maybe its not opening. Is the coolant filled to the recommended level?
Old 02-13-2004, 07:27 PM
Re: water pump?
Any ideas???
The tsat is only 2 months old, but its about in the right spot. My overflow is full though.
Old 02-13-2004, 07:46 PM
Bronco2 Bronco2 is offline
Re: water pump?
Correct me if I'm wrong,but isn't the low coolant switch mounted in the radiator of that car? Just because the overflow is full doesn't mean the rad. is full. A bad rad. cap will cause this. However,the leak needs to be fixed first.
Old 02-13-2004, 08:21 PM
Re: water pump?
I cant tell where it is leaking from - no noticable blown hoses...
Old 02-13-2004, 08:22 PM
Ripn12s's Avatar
Re: water pump?
If its filling up the overflow bottle then its probably spilling out of there. I know when I lost my belt on the highway the car overfilled the bottle and I had coolant all over the place.
Old 02-13-2004, 08:24 PM
Re: water pump?
someone said maybe a leaky intake gasket??
Old 02-17-2004, 05:59 PM
Re: Re: water pump?
Boo Hoo - It was the throttle body assembly. Not good as it was exensive to have done....
Old 02-17-2004, 11:12 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: water pump?
Sorry
Costs on water pump for 97 Grand Am? CindyLynn Grand AM 1 12-02-2010 02:06 PM
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 08:55 AM
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
Water Pump Gasket & Sealant/ Tensioner O-ring Questions Make 'em Last Grand Prix 2 06-06-2009 01:17 PM
