Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-13-2004, 03:58 PM
publicenemy137's Avatar
publicenemy137 publicenemy137 is offline
Send a message via MSN to publicenemy137
Question how do you replace the low-beam bulbs of a 95 240sx??
hey I just bought some osram silverstars, 9003, and wondering how to replace the bulbs.
I first twisted off a ring which exposed a rubber backing about the size of a coaster covering the back of the bulb. Not sure what to do and there doesn't seem to be anything to unscrew and don't want to just start pulling. How do I get the bulb out?
Old 02-13-2004, 04:07 PM
vsiev vsiev is offline
Send a message via AIM to vsiev
Re: how do you replace the low-beam bulbs of a 95 240sx??
want the fsm for your year to help you out?
Hiya...
Need a FSM? Hit me up I'll send it to ya for FREE!
I only have the 91-98 240sx, s13 ca18det, and s14 sr20det FSM
Sorry no 89-90 yet....
Mods:
Tein Flex with EDFC
Hotshot Header
R32 GTR Seats
Advan SA3 16x7 16x8
Apexi Dual N1 Exhaust
Silvia Front End Conversion
Digital Climate Control
Nismo 2-Way LSD
Injen Intake w/ CAI
Old 02-13-2004, 06:36 PM
sure
Old 02-13-2004, 06:55 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
That little rubber cover is the power source for the bulb. Just pull straight back and it comes right off. There is nothing holding it on. Once you get that off then you will see a little wishbone looking clip that is holding the bulb into the housing. just squeeze the sides of the clip and it will come loose which then frees the bulb.
Old 02-15-2004, 12:24 PM
finally yanked out that stupid power cord. Now the bulb is under this rubber and the clips are under the rubber, do you guys just use your fingers to pull in the clip and take out the rubber and bulb out??? Also did you guys take the headlight out or can I still replace the bulbs with the housing still screwed in?
how to replace a low beam head light mendori1 TrailBlazer | Trailblazer EXT 3 07-03-2010 09:59 AM
How do you replace the climate control bulbs? itzed Lumina 6 05-23-2006 11:46 PM
replacing projector low beam bulb? robby7 Exterior | bodykits | Lighting 0 03-28-2004 11:37 PM
4th Gen do you find the low beams are super dim? Accord Goblin Accord/TSX/Accord Hybrid 13 12-11-2001 05:27 PM
