Old 02-22-2010, 09:06 AM
mendori1 mendori1 is offline
how to replace a low beam head light
need to replace a low beam head light, don't know what i need to remove to replace it/ it is a 2005 trailblazer ls
Rick
Old 02-22-2010, 09:26 AM
maxwedge maxwedge is offline
A990 racer
Re: how to replace a low beam head light
L/s is easy just reach in behind the lamp housing, under the hood, remove the rubber cap to access the bulb, r/s remove the air intake duct to access the lamp.
Old 03-24-2010, 03:14 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Even easier than that. There are two flat horizontal tabs just above and behind each assembly near the upper radiator support crossmember. Pull up on those tabs to unlock the headlight assembly from the frame. It will be free to pull away from the truck...may even fall into your hand so be wary. Unplug the wires from the lamps to separate completely and twist to remove the lamps from the sockets. Install new lamps and reverse procedure to reinstall.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-03-2010, 09:59 AM
debkev debkev is offline
you have to remove the fron grille first to pull out the headlamp assy. 5 min . job.
