Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-12-2004, 09:11 PM
c32b1 NSX's Avatar
c32b1 NSX c32b1 NSX is offline
Send a message via AIM to c32b1 NSX Send a message via Yahoo to c32b1 NSX
quad throttle bodies
theres this mod for NA engines thats been makin me wonder what it does. does it increase horsepower and torque? by how much?
Old 02-12-2004, 10:05 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: quad throttle bodies
it should increase horsepower because bigger throttle bodies feed more air into the engine and more air means more to combust. with a bigger throttle body i would also buy bigger fuel injectors to get the air-fuel mixture perfect.
ZedEx Crew Member #2
Old 02-12-2004, 11:26 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
It does depend on the rest of the engine and the design. If the restriction on air flow into the engine is the cylinder head, or exhaust, etc, then a bigger throttle body will not give any more power at all.
However, if you are going to modify the engine for more power, such as bigger cam or head work, headers etc, then a bigger throttle body will help power for sure.
On its own, there may or may not be any difference.
Old 02-13-2004, 08:42 AM
SaabJohan SaabJohan is offline
For high performance engines it's common to have separate throttles for each cylinders as this increase power somewhat and improve throttle response.
Normal road cars has often quite small throttles as the larger ones have more of an on/off feeling.
?? about a throttle body mod thread 4x4chevymanS10 Performance 4 09-20-2009 11:32 PM
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 07:11 PM
quade throttle bodies ?? whats up with that Tranzlogic Engineering/ Technical 23 05-11-2005 04:32 AM
4ag quad throttle bodies c32b1 NSX Corolla/Matrix/Voltz 3 07-18-2004 11:44 AM
Ebay: Quad throttle bodies for B16A Setanta '88 - '91 Civic | CRX | Wagon | Shuttlee 7 07-26-2003 10:12 AM
