Old 02-12-2004, 06:26 PM
blade34609's Avatar
blade34609 blade34609 is offline
Lower Balljoint
Hi,
I went to put my spindles back on.
The upper balljoint when on perfect and the tie-rod balljoint also went on perfect.
But when I went to tighten the lower balljoint it got tight at first then started spinning on itself. No matter what i do it jus spins the whole balljoint.
I really dont wanna get a whole new spindle and i heard lower balljoints are a bitch to do. Is there a way to hold it in a way so that the balljoint doesnt spin when i tighten it. It worked perfect before i loosened it up.
Please help.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 02-12-2004, 08:28 PM
wickedplastikman wickedplastikman is offline
Re: Lower Balljoint
if any of the bolt is sticking out past the castle nut, then use vice grips on it to hold it. you don't have to really tighten the castle nut that much. make sure that it is snug and as long as you can put that pin back in, you should be fine.
99 teg ls turbo:
Drag gen III turbo, Blitz BOV, Blitz Boost Controller, AEM Standalone ECU, MSD Ignition, MSD Blaster SS Coil, MSD Cap, Skunk2 Intake Manifold, AEM Fuel Rail/Fuel Pressure Regulator, ACT XCT Clutch, ACT Aluminum Flywheel, Nex SS Coilovers, Thermal Stainless 3" Exhaust, Skunk2 Short Shifter/Knob, Rota 15" Black Slipstream Wheels, Falken Azenis Tires, Brembo Rotors, Axxis Metal Masters, Type R Wing/Seats, VIS Carbon Fiber Hood
1994 GMC Sierra 2WD Lower Balljoints aldredr6 Sierra 2 03-29-2007 10:52 AM
lower balljoint on '93 grand prix???? JimofWare Grand Prix 3 06-21-2005 10:09 PM
Sonoma Recall-lower balljoint anyonw know? batman19 Sonoma | S-15 1 03-23-2005 11:01 PM
Lower Balljoint Removal? blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 09-18-2003 10:10 AM
Lower balljoint question stinger95 Continental 3 01-29-2003 08:29 AM
