Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-10-2004, 10:59 PM
jay02's Avatar
jay02 jay02 is offline
Angry Prostart CT-3300 Install problems
I'm getting very frustrated... ok heres the situation, I recently bought a Prostart CT-3300 from Canadian Tire (canada of course) and I've been trying to install it.. it took a while but i finally got to the point where it was turning over, and it would start but then imediately shut off. I figured that i must have had the wrong tach lead so i found what i think is the right one and tried it.. and it worked.. well for about 10 starts.. now its back to where i was before.. its starting then immediately cutting off... any suggestions?
Old 04-16-2004, 06:39 AM
Fred Tinkler Fred Tinkler is offline
Re: Prostart CT-3300 Install problems
Jay,
I have the same prostart model, but I havn't tried to install it yet, but the manual says you have to put the module through a "tach learning" process. Check your installation manual.
That may be the problem, otherwise I don't know.
Old 12-30-2005, 10:53 PM
D.Gosser D.Gosser is offline
OK guys. I just installed the Prostart 3300. I suggest you try putting a key in the ignition and try the remote starter. If this works then I am assuming your ignition is protected by a passlock or passkey system, which will require a bypass module. Good Luck.
Old 12-20-2006, 06:57 PM
Sparkadelic Sparkadelic is offline
I am having the same issues as your initial problem. Start for a second and shut down. Wondering how you rectified your problem?
Old 12-20-2006, 08:11 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Reviving threads started in 2004 isn't a good way to do that...
If that user is still around, try sending him an email or PM. That way we don't get the old thread, and you get you answer quicker.
Dragging people kicking and screaming into the enlightenment.
Prostart CT 3300 No start and 3 blinks? XXXJAYXXX33 Engineering/ Technical 10 11-18-2011 10:33 PM
ProStart CT-3300 in Pont. Grand Am satmanduo Grand AM 1 02-08-2007 10:20 AM
Prostart ct-3300 command start Fire_98 Engineering/ Technical 0 12-02-2006 07:07 PM
ProStart CT-3200 Mekkano Escort 1 11-22-2005 11:26 PM
1991 Mustang Conv. ProStart Ct-3100 njti Mustang Talk 2 09-27-2004 06:35 PM
Closed Thread
