Old 02-07-2007, 10:46 PM
satmanduo satmanduo is offline
ProStart CT-3300 in Pont. Grand Am
Going to install a CT-3300 prostart Remote Starter with Lock/unlock. From the reading in the forums I notice not all wires are needed.
Im installing this in a Pontiac Grand-am (1995) 4dr 3.1 litre, I have experience with automotive wiring, and wanted to only hook up what is needed.
The 6 pin harness on the RS unit is : Yel (ign), Red (12v Batt), Orange (accessories), Purple (Starter), Green (5th Relay), Red (12 volt Battery) : is the Org and Green needed?
The 5 pin harness on the RS unit is: Black (gnd), Purple (Tach), Grey (Hood SW.) Orange (brake sw), Yellow (Parking Lights) : all are needed(?)
The 12 pin harness on the RS unit is: Blue(trunk), Brown(lock), Green(unlock), wht/brn (re-arm), wht/grn (disarm), blu/wht (Aux1), wht/org(start kill), Org(neg. prking lights), Purple (EXT, Trigger), Wht (gnd - when running), Grey (n/a), Yellow (Glow plug) : Just need the Lock/Unlock here I would suppose (what about relay? any model number to use, never hooked up a relay before).
Just the Start, Lock and Unlock is the only circuits I really need for this car. Trunk is a cable not motor
Any and all help/suggestions would be appreciated
Old 02-08-2007, 09:20 AM
Brandish's Avatar
Brandish Brandish is offline
Re: ProStart CT-3300 in Pont. Grand Am
You will need the orange for sure in the 6-pin harness; that will activate the blower so the car will heat up. The green one you will only need if the car has a 2nd ignition wire. If it does have one, it should be a blue wire, so connect the green to that one. You will need every wire in the 5-pin harness, and only the green and brown wires from the 12-pin harness for your locks. Just keep in mind the lock wires are positive trigger in that car, so you will either need a door lock inverter or a couple of relays to make them work properly.
