Old 02-10-2004, 04:25 PM
jdmsource403 jdmsource403 is offline
B16a Help!!!!!!! Wont Start
ok guys i jsut finished installing a b16 in my 91 civic Si and everything i have double checked but when i went to start it, it cranks but does not turn over! any suggestions anyone??? also how can i check to see if my fuel pump is functioning?
Old 02-10-2004, 05:04 PM
SiZ's Avatar
SiZ SiZ is offline
Re: B16a Help!!!!!!! Wont Start
Any codes?
"The nympho of info, I'm fuckin' what ya heard"
Old 02-10-2004, 05:39 PM
91B16Civic 91B16Civic is offline
you should hear the fuel pump kick on if it is functioning by turning the key to the on postion and listen.
Old 02-10-2004, 09:03 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
check where the fuel line bolts to the fuel rail, when you loosen that bolt it leak a bit of fuel if the pump pressureizes when you turn on the ignition switch........
gunnmen01
My other ride..... is YOUR MOM !!!!!!
1991 wont start..motor from 1985 no spark HELP rwoodxtreme C/K 4 01-31-2010 10:19 AM
HELP 98 Venture Wont start or crank over Dtompkins Venture 3 12-02-2009 06:50 PM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
03 Eclipse rs wont start mrcontreras Eclipse 2000+ 1 02-27-2009 05:49 PM
