Old 02-10-2004, 12:37 AM
xplhavoc xplhavoc is offline
Lsd ????
Ok heres my problem, LSD tranny and just replaced the master and slave cylinders. Its a hydro. Before i did that the tranny was making a noice when i push in the clutch most of the time and sometimes acts perfect. I think i can slightly hear the cyncro. Clutch doesnt slip at all. Sometimes i cant get it in gears while driving hard or slow. Should i change with a stronger clutch need any way, and change syncro?? Tranny is a good one from what i hear? How much to do this and wre should i take it to or do myself??
Thanks.
jeff
[email protected]
Old 02-10-2004, 01:43 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Not positive on the answer, but my friend had an H22a with LSD and he had the same problems as you described. It ended up being the syncro; finding it out when his tranny blew out and put a hole in his transmission case. So I'd check those if I were you, even if you decide to just get a clutch you might as well when you got the tranny off the block.
Old 02-10-2004, 02:27 AM
Re: Lsd ????
Thanks i agree..
jeff
Old 02-12-2004, 07:43 AM
juju4uofa juju4uofa is offline
Does the clutch disengage well before the pedal is to the floor? I've swapped a clutch before and had the adjustment on the pedal wrong. The clutch would disengage but if I pushed it to the floor it would make a noise. Check to see if this is the case and just adjust the pedal accordingly.
LSD in d16z6 transmission sohcd16beast JDM Motor & Parts info/chat 0 07-31-2010 03:10 PM
how to tell lsd from non lsd integra111 JDM Motor & Parts info/chat 11 08-22-2004 09:48 PM
Difference: LsD SiR & Non LsD SiR... B1SiR6A Let's get Technical! 3 04-01-2004 06:02 PM
b16a lsd vs b16a non lsd 91blublaze Engineering/ Technical 16 10-14-2003 03:20 PM
Does anyone have a quaife LSD installed on their lude?? justin@af General Discussion 2 03-25-2002 12:09 PM
