Old 02-09-2004, 04:02 PM
Blackout Blackout is offline
Tamiya Flat Base
I recently bought a jar of Tamiya Flat Base. Has anyone ever used this product? If so, how does it need to be applied. Can I put it over a glossy painted item, and it will dry with a flat look, or does it have to be mixed before applying?
Old 02-09-2004, 06:04 PM
freakray freakray is offline
AF Modelrater
Re: Tamiya Flat Base
It has to be mixed with a regular color, you can't apply it on its own.
Flat base is a paint additive you can use to make a regular Tamiya gloss color into a satin or flat color depending on how much flat base you add to the color.
Old 02-09-2004, 07:27 PM
RallyRaider's Avatar
Zomby Woof
As Ray said it has to be mixed with another colour. If you want a clear flat topcoat all you need to do is mix some with the apropriate Tamiya gloss clear. Make sure you only add small amounts and test otherwise you coould add too much and end up with a messy slurry.
Old 02-12-2004, 12:56 AM
clem24 clem24 is offline
Or you can buy Testor's Flat coat...
clem..
Old 02-12-2004, 06:40 AM
pcmodeler's Avatar
pcmodeler pcmodeler is offline
Be careful. If you mix in too much it will actually start to turn white.
Old 02-13-2004, 04:53 PM
fola's Avatar
fola fola is offline
Send a message via Skype™ to fola
that is something i allways wanted to know!!
Old 02-13-2004, 04:56 PM
fola's Avatar
i actually tried to apply it over the color...........
it did actually turn white, but luckily enough i managed to wipe it off......
Flat base clear gloss coat? White primer Grey Primer? AllAlone.Gz Car Modeling 4 12-25-2006 06:42 AM
Blue + Flat Base? (Renault 5 Turbo painting) SteveK2003 Car Modeling 6 03-04-2005 11:31 AM
Tamiya Flat Base HURT77042 Car Modeling 6 08-12-2004 09:48 PM
Tamiya Flat Base? shieldwulf Car Modeling 8 09-14-2003 11:56 PM
Tamiya Flat Base (X-21) ales Car Modeling 6 01-30-2002 03:34 PM
