Old 09-12-2003, 11:11 PM
shieldwulf's Avatar
shieldwulf shieldwulf is offline
Tamiya Flat Base?
What is the purpose of Tamiya Flat Base? Can anyone enlighten me on this?
Old 09-12-2003, 11:35 PM
The Lambrusco Kid's Avatar
The Lambrusco Kid The Lambrusco Kid is offline
AF Premium User
I love it!
It's a very handy "paint".
When you mix it with glossy paint it'll turn into flat paint. you can also just mix a little with any paint to turn it into satin paint.
that's about it.
... Oh yeah you could also air brush it over decals you've placed over tires to give it a flat texture...
__________________________
"Back off man, I'm a scientist."
Click banner to view thread
Old 09-13-2003, 02:57 AM
shieldwulf's Avatar
1) I am thinking of using it as a sealer to airbrush it over decals (to protect the decals from yellowing with time). Is this recommended?
Will it affect the decals, or should I use something like Micro Set to do the job?
2) Will the flat base paint become visible (or appear as a little shiny patch over a matt body colour) after spraying it over the decal area?
Thanks.
Old 09-13-2003, 04:28 AM
Ragnarok043's Avatar
Ragnarok043 Ragnarok043 is offline
Send a message via AIM to Ragnarok043
i wouldnt reconmend using straight flat base, theres a likelyhood that it would leave a frosted finish. flat base is really only meant to be mixed with other paints. it might work if you mixed with some clear gloss paint, but it would be less hassle to just use a dullcoat instead.
Old 09-13-2003, 05:30 AM
Lambo003's Avatar
Lambo003 Lambo003 is offline
I just wanted to add that you can use the flat base on chrome plated parts to give them a brushed/satin aluminum finish.
Any brand of clear flat will work when airbrushing or using a sray can (such as Testors). However, I've found that for regular brushing nothing beats Polly-Scale flat base (leaves less brushmarkes).
Chuck
Old 09-14-2003, 12:41 PM
Murray Kish Murray Kish is offline
Getting Old...
I sprayed flat base through my airbrush and it ended up turning 'frosty'. Base on that, I think it's meant to be mixed with something else, not used on it's own. I have mixed it with Future (about 1/3 flat, 2/3 future) and it ended up being a nice satin texture. I've heard that you can go up to about 50:50 and get a nice flat coat.
Murray
Old 09-14-2003, 01:45 PM
mel79's Avatar
mel79 mel79 is offline
Flat base isn't meant to be used alone at all, only as a paint additive. If you use flat base straight from the bottle it'll result in a chalky frosted coat which doesn't even stay well on surface. So only use it by mixing it with other Tamiya paints.
-Mikko
Old 09-14-2003, 02:28 PM
Rtuned's Avatar
Rtuned Rtuned is offline
when I was young, I used it just from the bottle, it turn frost powder on surface...but just like the effect...look like snow to me.
Old 09-14-2003, 11:56 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Just brush paint the flat base on a runner, (clear part is better) to see the effect. With flat base, you control the flatness of paint. Some people learn the hard way, becuse there are flat clear "topcoat" from various manufacturers.
Hiroaki Fukuda
Flat base clear gloss coat? White primer Grey Primer? AllAlone.Gz Car Modeling 4 12-25-2006 06:42 AM
Blue + Flat Base? (Renault 5 Turbo painting) SteveK2003 Car Modeling 6 03-04-2005 11:31 AM
Tamiya Flat Base HURT77042 Car Modeling 6 08-12-2004 09:48 PM
Tamiya Flat Base Blackout Car Modeling 6 02-13-2004 04:56 PM
Tamiya Flat Base (X-21) ales Car Modeling 6 01-30-2002 03:34 PM
