Old 08-10-2004, 09:08 AM
HURT77042 HURT77042 is offline
Send a message via AIM to HURT77042
Tamiya Flat Base
Man. WTF? I have ran into another problem while converting from always using enamels to Tamiya Arcylics for brush painting.
I know you probably hear these same questions time and time again, but I have tried desperatly hard to search all the posts for an answer. I mixed the Tamiya Flat base with the Color Arcylic I was using 1:1 (just like directed) and it didn't turn out right. I was told to try and paint with the arcylic first and then add the flat base, however that just left a white film that was a pain in the butt to get off. What am I doing wrong?
Old 08-10-2004, 10:38 AM
Bigsasquatch Bigsasquatch is offline
Re: Tamiya Flat Base
Well I am no expert but I read that as long as you keep the flat base below 30% you dont get the white film...... If you exceed 35% then the white film appears.
As I say no personal experience, just read it somewhere
Cheers
BIG"S"
Old 08-10-2004, 10:45 AM
freakray freakray is offline
AF Modelrater
Make sure you mix the color and flat base thoroughly, it may require a little thinning as flat base tends to thicken the paint.
Flat base is an additive, it should not be applied on its own as you will only get the milky white film you saw when it dries.
AF User Guidelines
Old 08-10-2004, 12:48 PM
ales's Avatar
ales ales is offline
Forza Schumacher
1:1 is definitely too much flat base. Try adding 5 to 10 % of flat base to gloss paint and then modify that ratio to suit your needs, 50 % is way too much.
Old 08-10-2004, 04:43 PM
willster127's Avatar
willster127 willster127 is offline
Throw the Tamiya Flat base away and get some model master flat clear acryl, paint the part glossy and then paint over with the clear.
Of all the Tamiya products the flat base is the only one I detest, once I found the model master all problems went away. The only thing flat base is good for is for using in place of Tamiya Flat White!!!! I use it for brake master cylinders, batteries and the like and think the finish is much better than the standard white!!
The Willster....
Old 08-10-2004, 04:53 PM
Great, Thanks for all your comments. It's good to know I am not a complete idiot! Ha.
Old 08-12-2004, 09:48 PM
bvia's Avatar
bvia bvia is offline
Take Wilster's advice and send me your Flat Base!!!...;-)>
As stated, Flat Base is a flattening agent that contains an extremely small grained white powder in a thick acrylic carrier. The powder grains causes the paint to dry to an unlevel surface and therefore a satin or matt paint surface results!
Practice makes perfect but I rarely go over 20% FB solution.
hth,
Bill
"Why yes, that IS my bare, carbon fiber Enzo in Scale Motorsport's "How to Carbon Fiber Decaling video!"
