I have a '99 honda civic hatch and I need someone to tell me how to replace the front turn signal bulb... It seems I can't get to it without taking something apart which is too much work for a bulb replacement...
Re: Turn signal bulb replacement
yeah, you will have to take your front bumper off so you can acess the lights then take the light assembely ut to get to the turn signals, honda makes it soo difficult. give it alittle twist and it should come out.
To get the bumper off: there are 6 snaps you have to take off on the of the grill. Then 1 screw in each wheel well and 2 bolts on the bottom of hte car. Then t should come right off. You need a 10mm wrench and a phillips head srew driver to take everything out To take the light assembly out: On top of the light there are 2 bolts, after you have the bumber off in the corner near your fenders there is another bolt. Then near where your grill was should be 1 bolt on each side. If they do ot slide out, the metal bracket that is infront of the lights have to come out. take the 2 bolts out and then the light can pop right out to put back together, do everything backwards, should take you about 40-45 min to do. hope this helps need anything else contact me |
