Old 10-18-2004, 02:58 PM
triniu2 triniu2 is offline
Question rear turn signal bulb replace?
Anyone know of a web site that has a "how to" for replacing an alero rear turnsignal bulb? Want to know if it's worth the trouble of doing myself.
Thanks,
John
Old 10-18-2004, 10:33 PM
JTrujillo86 JTrujillo86 is offline
Re: rear turn signal bulb replace?
It's really simple. Open your trunk and look on the inside of the trunk right about where your bulb would be. There is a little plastic screw that holds the trunk carpet on. Remove that screw and pull the carpet back. There are going to be about three or four more screws that you should see. These hold the lighting assembly to the body, so when you begin to remove thses, hold the lighting assembly with your hand that way it doesn't fall onto the street and crack. Then pull the lighting assembly away from the body and there is a little panel that unsnaps. There are your lights. Install is just the reverse.
Jeremy
Old 10-19-2004, 07:50 AM
Smile thanks!
Thanks for the step-by-step! I'll pick up a bulb and give it a try tonight, doesn't sound too bad.
Thanks,
John
