How many ponies u think I got???
Like anyones opinion
on what they think this motor may be pushing and what kind of track times it could pull with good drivng. Thanks. The new motor is a 306 built by New York Speed. It has ARP rod bolts, TRW forged pistons, SPD Pro molly rings, clevitt main bearings, Ford Motor Sport E303 Roller cam, GT40 cylinder heads, ported and polished, Ford Motor Sport 1.6 aluminum roller rockers, ARP head bolts, Ford Motor Sport push rods, Motor Sport hydraulic roller lifters and retainers, GT40 upper and lower intake manifold, BBK 70mm throttle body with EGR plate, Ford Motor Sport 24lb. injectors, Pro M 75mm mass air meter, BBK cold air induction, Motor Sport aluminum under drive pulleys, 3 core radiator, MSD cap and rotor, MSD ignition coil, Motor Sport wires, BBK fuel pressure gauge, 255 fuel pump, BBK shorty equal length, BBK off road X pipe, 2 chamber flows, Tremec 3550 five speed trans with Motor Sport clutch , B&M ripper shorty throw shifter, Ford Motor Sport aluminum drive shaft. The rear is a new 8.8 with 3.73 gears and 31 spline axles, Ford Motor Sport traction loc posi unit, 1 1/2" JBA lowering springs, Lakewood upper and lower rear control arms, welded sub frame connectors, rear Cobra R sway bar.
95GT - Mac Longtubes, off road H, cat back, Mac pulleys, cold air kit, Ebiach sport springs, shock/struts, pro 5.0 3:73 gears, subframes, and Eagle Cobra R's. Car is a unique GT "S" Future mods - Mass air, Throttle body, nitrous! |
Kinda depends on what the specs of those pistons are.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
Re: How many ponies u think I got???
Looks like 325-350hp to me, the 1 1/2" JBA lowering springs alone should yeild about 50hp not to mention the sway bar.
No for real: 325HP 13.2 ET Quartermile 95GT 12.8 ET Quartermile 89LX PS...Very strong engine should be very reliable |
5 1/2 doh
yeah that would help, I wish I knew. The compression on the motor does seem a little higher than my 95. I can't even bump the timing to 14 or anything or it will detonate. I think I have the timming at 10 but can't remember.
yeah I bet WhiteCavaliac (lol) I just did a cut and paste that I already had saved for everything the car had. I should have skimmed through it more. As far as it being reliable, so far it's been a great motor with no problems at all. I bought a 90 that had it about 4 months ago and so far so good. Thanks for the reply.
So what did you do to "make" it a GT "S"?
ummm, it came that way. 95 was the last year gt "s" were made. look up gtsmustang and you'll understand. The car had a rare red on black interior, no power windows,door locks or even cruise. Just the 5.0 and a cd player. It was a option type car or something and only so many were made. how do you post a pic and how do you change your profile
interesting..........does it say gts on the badging or is it just labeled that way in the paperwork. I have a 95 Cobra maybe I could just say it's a Cobra S because it sounds cool
I hope your being sarcastic...
nnnnnnnnnoooooooooooooooooo................yeeeeee eeeeeesssssssssss..........
oook
Re: Re: How many ponies u think I got???
Do a search and you'll find a few topics where the GTS was talked about by myself and a few other members.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
thanks hiflow, so have you ever ran you 89
Maybe 10.
