Wiring from battery to fuse panel
I have a 94 S-10 Blazer 4.3 (TBI) When I turn the key there is nothing. I have 12v at the battery no volts in the fuse panel. Is there a ignition switch connector in the steering column? There is a purple wire from the starter, does that go to the switch ? How do you get to the connector?
Im havin the same kind of problem, i have no idea what it is... tomorrow im going to work on the truck and if i find anything out i will let you know
Re: Wiring from battery to fuse panel
hey, i had the same problem... in my case it was a loose battery connection... my father said he had the same problem but, on his he tightend the post so tight that it pulled the female lead connector out of the battery it self and the battery didnt work any more.. i would try to replace the battery and see if that works, also on mine i cleaned the posts and bolts and that worked for me.. good luck
