Go Back   Automotive Forums Car Chat > Nissan > Frontier | Navara
Old 11-20-2004, 12:52 AM
j4ckd0tcom j4ckd0tcom is offline
need help runing AMP wire from battery inside!!
ok, im learning this for the first time and i dont want to mess up anything. im sure i should not do it myself but its something a mans just got to do. I cant seem to find a way to get the wire through, so if any other Frontier people could tell me how to get it through please help me out. thanks.
-j4ckd0tcom
Old 11-20-2004, 08:28 AM
garync1 garync1 is offline
Look deep under the dash were other wires run through the fire wall or even AC lines run through. There also have rubber gromests around them use a wire fish or a coat hanger to help u put the wire through be very carefull not to mess up the wires or AC lines just take your time.Mine ran through with a wire harness under the dash and under the carpet close to the door seal to under the pasanger seat had to take the seat out though ,not hard.. but the amp was a very tight fit.
Old 11-20-2004, 11:34 AM
Frontin' Frontin' is offline
Send a message via MSN to Frontin'
Re: need help runing AMP wire from battery inside!!
what i did with mine, us like right under the front passenger seat, theres a hole under the carpet. so i ran it under the truck and used zip ties to keep it way up against the cab as close as possible, and then covered the wire with a weather/water proofing plastic. and then ran the wire to my back seats where my amp is....it was really easy. i had ur prob it took me hours and hours to find a whole to run my wire. god it was a bitch!
Old 11-24-2004, 07:48 AM
Oh forgot to say start from under the hood at the firewall you will see the wire harness or ac lines what ever you prefer fish them in from the out side to the inside.
Old 11-24-2004, 05:47 PM
how did u fine the other side? lol i could find the holes on the engine side, but when i went under my dash i couldnt see them or get to them. its to late now my way works fine, but it would still be nice to know...did u have to take a shit load of stuff under the dash off or the dash apart?
Old 11-27-2004, 08:45 PM
goinfshin's Avatar
goinfshin goinfshin is offline
Send a message via Yahoo to goinfshin
theres a rubber grommet on the passenger side firewall, just cut a small hole in it and run the wire in the cab, its very easy to find, run it under the carpet to the kick panel. get a phillips screwdriver and take the kick panel off, and you will have easy access to the rear of the truck under the carpet. do it like that and youll never see the wire inside the truck.
Old 12-11-2004, 12:12 PM
yeah i know how to do all the wiring and shit. and i found those rubber things on the engine side...but when i got under the dash i could never find it...what do i do there? i took a bunch of crap out like all the fans and shit or whatever it was, and the glove box, and still couldnt see it...am i just blind?
Old 12-13-2004, 08:01 AM
goinfshin's Avatar
yes
Old 01-21-2005, 10:02 AM
323'er 323'er is offline
Careful...
On our 2002 frontier, my hubby (an electrician) tried to put a sub in it, and in the process, blew SOMETHING. (It wasnt the fuse! Might have just been the radio itself...) He couldnt figure it out, so for months we rode around without a radio......
Old 04-29-2005, 02:47 AM
Vinhtvu2 Vinhtvu2 is offline
Make sure you run your Power line and your RCA cables on different side! Or else you'll hear static instead of music!!!!
I ran the power on the right hand side... because my battery is on the right hand side...
Yeah... I had a couple problems running mine too... Some reason, after I ran my system, the Airbag light keep on blinking... the driver side one... I have no clue if I blew a fuse or something... I checked all the fuse and they're all good... No clue what's wrong!
