Old 02-05-2004, 09:13 PM
jacer jacer is offline
Send a message via AIM to jacer
Crx Fuel Injector Resistor Box?
Anything Different Between Crx Hf Resistor Box,and A Crx Si ??
Should I Use A Si One ,or Keep The Hf One? Thanks
Old 02-05-2004, 09:24 PM
lilol89crx lilol89crx is offline
Re: Crx Fuel Injector Resistor Box?
both are one in the same.....
Old 02-05-2004, 10:25 PM
travagliante's Avatar
travagliante travagliante is offline
Doesnt matter what honda you get it off of, as long as its obd0 with saturated injectors.
Why are you even changing a resistor box. Did it go bad or somethin.
Old 02-06-2004, 08:30 AM
91civicDXdude's Avatar
peak & hold. saturated is 92+
Old 02-06-2004, 10:59 PM
thanks 91 civicdxdude. I couldnt remember if it was peak or saturated.
Old 02-06-2004, 11:56 PM
Thanks For The Info Guys ,
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 01:06 PM
b16 injector resistor box dagoEF '88 - '91 Civic | CRX | Wagon | Shuttlee 0 10-13-2004 03:41 PM
Injector Resistor Box samamorgan '88 - '91 Civic | CRX | Wagon | Shuttlee 12 10-08-2004 08:18 PM
Injector resistor box oldschoolcivic '88 - '91 Civic | CRX | Wagon | Shuttlee 5 08-02-2004 03:24 AM
Injector resistor Box problem blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 07-23-2003 05:50 PM
