Old 10-01-2004, 06:12 PM
samamorgan samamorgan is offline
Injector Resistor Box
Hey all,
Im switching a DPFI for a MPFI and ive got most of the parts, except the distributor, and the resistor box. I was wondering, where is the injector resistor box located on these cars? Since i dont have one on my std hatchback, ive got no real idea where to look. Anyone know? Also, will any resistor box work with this thing? im switching to a D16A6. Thanks for any help
Old 10-01-2004, 06:17 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: Injector Resistor Box
Hi Noob, welcome to the forum
The box is near the brake booster on Si Civics and CRXs. They are easy to find in the junkyard and while your there you can grab the dizzy too. GL
PS as far as I know the DPFI cars don't have one.
Old 10-01-2004, 06:31 PM
Thanks a bunch. I just got back from the junk yard, and realized id forgotten to get it . I probably could have found it if i would have looked and known what it looked like, but i didnt. I also tried to get the distributor while i was there, but they didnt have one, so tough luck for me, gonna have to go somewhere else.
BTW: Thanks for the welcome
Old 10-01-2004, 06:39 PM
Posey88cvic4dr's Avatar
Posey88cvic4dr Posey88cvic4dr is offline
Send a message via AIM to Posey88cvic4dr
The injector box is in the top right corner under the hood
4g4d4Life <--Link To My Car
TEAM CHOZEN
Old 10-01-2004, 07:32 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: Re: Injector Resistor Box
i am also doing the same thing,dpfi to mpfi,
I dont have the distributor or a resistor box,
but :
http://www.fourthgenhatch.com/mpfi.html
says you dont need a mpfi distributor,or do ya?
just tap the CPS,
also on the 1st/top picture on that site,
i dont have that metal box on top of the throttle w/a vacuum hose going into the middle,whats that called?
or will I really need it?
sorry to take over in your post,but it was about the same subject
In the process of B00stin my D
Old 10-01-2004, 08:03 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
taken from forthgenhatch.com
Parts for MPFI on DPFI engine
MPFI Manifold (D16A6, Si engine)
MPFI Distributor (D16A6)
Injector Resistor Box (most all Honda ones will work but I recommend getting an Si one)
Injector Plugs (if your Manifold doesn't have them)
PM6 Si ECU
clearly says you need mpfi dizzy.
Old 10-01-2004, 08:22 PM
johnb16a2's Avatar
I concur
Old 10-08-2004, 01:51 AM
EF_CaSe EF_CaSe is offline
Send a message via AIM to EF_CaSe Send a message via Yahoo to EF_CaSe
Re: Re: Re: Injector Resistor Box
is it nomarl i gotta 90 Dx with a 99ls n i have no resistor box !! it still runs like a champ i guess im special
[]D [] []V[] []D ........ []D [] []V[] []D
Old 10-08-2004, 09:00 AM
johnb16a2's Avatar
Re: Re: Re: Re: Injector Resistor Box
I think they switched injector type at some point to eliminate the resistor box.
Old 10-08-2004, 12:27 PM
Forunn Daberator
by the way if you need a resistor box someone baught all my mpfi stuff except the resistor box, PM me if you want it.
Old 10-08-2004, 01:58 PM
if nobodys interested,how much u want for it shipped?
I need one bad & a pm6 ecu...
Old 10-08-2004, 03:41 PM
Forunn Daberator
$15 shipped
Old 10-08-2004, 08:18 PM
travagliante's Avatar
travagliante travagliante is offline
i got a pm6 ecu. Make an offer...
or i have also 1 extra pg7 ecu off a 1st gen. i believe a 88 teg. Works the same but has more aggressive fuel maps, and a higher rev limit.
Make offer on anything.
PM me or email me at [email protected]
