Old 08-01-2004, 04:23 PM
oldschoolcivic's Avatar
oldschoolcivic oldschoolcivic is offline
Injector resistor box
Where does the other wire on the resistor box go, should it hook up to the ecu like an SI or the SIR. (b16 sir going into 89 lx).
Old 08-01-2004, 06:14 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Injector resistor box
could you explain a little more about witch wire your talking about?
Old 08-01-2004, 06:23 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
oh come on you know what he means; THAT wire
maybe this will help: http://www.honda-tech.com/zerothread?id=222366
Old 08-01-2004, 07:53 PM
I mean come on if you look at the resistor box there is four wires comming from the injectors then there is that other wire. No idea where it goes.
Old 08-01-2004, 08:02 PM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
http://fourthgenhatch.com/mpfi.html . That page should answer all the questions you might have about the MPFI wiring/swap.
DOHC ZC 89 DX HATCH
Old 08-02-2004, 04:24 AM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
since they'v posted those links, i take it you've discovered where that wire goes?
