Old 11-24-2008, 11:58 PM
skyler521 skyler521 is offline
2001 S10 Tail Light/reverse lights
My right tail light went dim on me and if i had the truck in drive the break would cut both tail lights off.. I found a yellow wire connected to the black wire on the right side and pull on it and it worked perfectly, allowing my backup lights and both tail lights to work fine. I figured the wire was grounding out somewhere so i replaced it (it ran from the right side to the left side) after doing this my turn signals worked right and my break lights worked right but i lost my tag light and running lights in the back. also my gauge light and marker lights on the head lights stopped working completely..
anybody know where i can get a wiring diagram of the tail lights or have any ideas what could be going on.
Old 11-24-2008, 11:59 PM
edit : 2001 S10 Tail Light/reverse lights
skyler521]My right tail light went dim on me and if i had the truck in drive the break would cut both tail lights off.. I found a yellow wire connected to the black wire on the right side and pull on it and it worked perfectly, allowing my backup lights and both tail lights to work fine. I figured the wire was grounding out somewhere so i replaced it (it ran from the right side to the left side) after doing this my turn signals worked right and my break lights worked right but i lost my tag light and running lights in the back. also my gauge light and marker lights on the head lights stopped working completely..
I checked every fuse on the truck and theyre all good.
Old 11-25-2008, 08:19 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2001 S10 Tail Light/reverse lights
Bad ground?
A good volt/ohm meter or test light will show a bad ground.
On checking fuse check for power to it and threw it.
For wiring diagram.
Factory repair manual or all dara online sub.
http://www.alldata.com/products/diy/index.html
Also a lot of public liabarys hav car repair info.
Good luck
MT
