Old 02-05-2004, 01:31 AM
soyee7's Avatar
soyee7 soyee7 is offline
Banned
10 sec eclipse!!
Hey, id like to build a 10 sec 1st gen talon. I was wondering how hard it is to do this. Im also a member of my st. louis bord and all the guys in there act like its impossible and that the motor will blow up even when built. They also say that with all the airflow piping like intake exhaust and IC, and a big 16g turbo, that my talon will barley be in the 13s. What do you guys think about these homos.
Old 02-05-2004, 05:38 AM
1qwik4 1qwik4 is offline
Send a message via Yahoo to 1qwik4
Re: 10 sec eclipse!!
I say with the aboved mentioned items, you would probably be running 13's on pump gas and maybe somewhere in the 12's on race gas depending on how good of a driver you are. Is the car an AWD or FWD? A 10 sec 1/4 mile is no joke, it takes money, time to build it, and a spare car (for transportation when your other one is broken).
Old 02-05-2004, 06:39 AM
NJ4cF3d NJ4cF3d is offline
it is possible, my friend had a g1 and it was a beast, very expensive though, he bout a beater of a talon rebuilt the engine... slapped on monster turbo with all the electrical gear you need, ecu and fuel... was ripping the shit outta anything... it was AWD ill get pics and stats later, i have to go to class
Old 02-05-2004, 01:21 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
it's a 1g, as in 1st generation... it is very possible if you have an AWD. FWD will be much more difficult. 10s is VERY fast. fortunatly you have the powerplant to do it. ask your friends if their motors will go to 450hp on stock internals. i think that mid-upper 11's are the max a 16g will do. 12's are very attainable, even for FWD.
Old 02-05-2004, 03:25 PM
soyee7's Avatar
Banned
its a auto, awd talon. with an aftermarket torque converter.
Old 02-05-2004, 04:04 PM
Re: Re: 10 sec eclipse!!
you can do alot with that. you can build boost on the line with an at too. but i'm not sure how much power an AT will hold together...
Old 02-05-2004, 11:13 PM
kjewer1 kjewer1 is offline
AF - Advisor
The ATs do well up to 350 or so, as I understand it. You can get the end clutches upgraded and shift kit installed which prepares it for over 400 HP. Auto trannys can take a good deal of torque before they break, its the clutches you have to worry about. Since the TC is already upgraded, the above mentioned mods will make a nice difference.
Here is my take on the "I want to build a 10 second car" idea... First build a 13 second car. Then build a 12 second car. Then build an 11 second car. Then build a 10 second car. You will learn more and more as you go faster and faster. Tuning mistakes are ok in the 13s, but in the 10s they are disasterous. We all have to walk before we run. Take your time, and learn the process one step at a time
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-06-2004, 02:36 AM
soyee7's Avatar
Banned
thanx, ill definetally take my time doing so, i just wanted to make sure it was an abtainable goal. I appreciate your input 95GSXracer.
Old 02-06-2004, 02:45 AM
89Turbo944's Avatar
89Turbo944 89Turbo944 is offline
If you have money you can do anything you want. 95 GSXracer is the god around here. If you ever have a question talk to him. He willmost likley be able to answer it.
eclipse GS 00 Racing jls89 Eclipse 2000+ 2 05-15-2010 05:53 PM
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
1998 mitsubishi eclipse rs flywheel question E. Frank Engine, Transmission and Drivetrain 4 08-22-2009 11:38 AM
95 eclipse gs blue smoke won't start hcruz32 Eclipse Problem Diagnosis 1 03-20-2009 09:36 PM
10 sec. eclipse smokeurass Off-Topic 13 10-12-2003 01:34 AM
