Old 02-01-2004, 01:59 PM
Eclipseoholic Eclipseoholic is offline
testing Idle air controller
How do u test this thing!!!!!!!!! i have the repair manual and no where does it say how to test it i need this car fixed its pissing me off!!! 91 mitsu 2.0L eclipse non-turbo!!!
Old 02-01-2004, 02:17 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: testing Idle air controller
No way to really test it, but you can at least check for opens or shorts in teh coils. Look online for the test, its out there somewhere. But it involves putting a meter across adjacent pins and the resistance should be within a certain range when its warm, or another range when its cold. I forget the numbers. It is also possible for a bad ISC to pass this test though, but I wont go into why. Check out the vfaq on idle control issues if you havent already, there are many other things thast can cause problems.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-01-2004, 02:26 PM
I was wondering if it is possible to take it off and clean it but i heard it might break is that true if i take it out to clean it
Old 02-01-2004, 02:29 PM
AF - Advisor
I have changed them before, and never broken one. But be careful, the plastic piece inside can get brittle over time. Another thing you can do to check it if you have it removed is to leave it plugged in, with the little platic tip where you can see it. Turn the key to the on position and see if it moves a good bit then goes back. If it just sits there twitching and not really moving, it could be bad.
Kevin Jewer
Old 02-01-2004, 02:33 PM
thanks
thanks so much i hope i find thsi stupid problem
97 Blazer idle air control valve test mansopoor Blazer 5 02-05-2011 04:51 PM
How do you test an Idle air control valve? usgoods Problem Diagnosis 1 01-07-2008 08:27 PM
FS: Idle Air Control ( IAC)- Idle Sensor Control (ISC) Killa Classifieds 10 09-22-2006 11:16 PM
94 Plymouth Voyager WON'T IDLE AHHH! Not EGR Not Idle Air Control HEELLLP! dadscarisaheadache Caravan | Voyager 3 03-28-2005 02:56 PM
idle air control///help testing coleman C/K 1 06-08-2004 10:35 AM
