Old 02-29-2004, 04:14 PM
dadscarisaheadache dadscarisaheadache is offline
94 Plymouth Voyager WON'T IDLE AHHH! Not EGR Not Idle Air Control HEELLLP!
Argh...
Dads Van is broke down, Going Crazy 3.3 v6 Runs Only when you pump the gas. Hold the peddle half way in where it should run at high rpm's dies right out.. Replaced Idle air Control Replaced EGR Valve Pressure in line seems good... Maybe some type of electrical malfunction? Really appreciate any ideas as we are out and hes going to loose what little hair he has left..
Thanks
P.S Dunno if it can be tested with a diagnostics in its current state, doesn't really run/idle It does run but only if ya pump like crazy on the gas peddle
Old 02-29-2004, 11:28 PM
Anaudiophile Anaudiophile is offline
Re: 94 Plymouth Voyager WON'T IDLE AHHH! Not EGR Not Idle Air Control HEELLLP!
Have you checked the fuel pump pressure?
Old 03-26-2005, 10:25 AM
paulsi paulsi is offline
Re: Re: 94 Plymouth Voyager WON'T IDLE AHHH! Not EGR Not Idle Air Control HEELLLP!
How about the gasoline filter ?
-Paul
Old 03-28-2005, 02:56 PM
typesix typesix is offline
How about major vacuum leak?
ICV Idle Control Valve not working squawcrk Cavalier Problem Diagnosis 1 07-03-2010 01:04 PM
1998 plymouth voyager need help fast and out of ideas pdragonz Caravan | Voyager 14 07-30-2009 12:06 PM
plymouth voyager won't idle at times wteter Caravan | Voyager 6 01-08-2005 06:47 PM
"94 Plymouth Voyager Won't start--HELP!! star254399 Caravan | Voyager 0 08-06-2004 01:40 AM
1990 Plymouth Voyager won't start roymoye Caravan | Voyager 1 12-14-2003 04:29 PM
