Go Back   Automotive Forums Car Chat > Buick > General Discussion
Old 01-31-2004, 01:14 AM
txcougar txcougar is offline
Gas leaking out exhaust manifold?
I hope you guys can help us out. My brother in law has an 83 Buick Lesabre with a 307. He claims iIt appears that gasoline is somehow leaking out the exhaust manifold and it has been terrible on gas mileage since he bought it a couple of weeks ago. He's also smelled gas coming from the engine compartment at times. It seems to be running okay other than this leaking gas and it only seems to leak when he first starts the engine? Hope someone can help.
Old 01-31-2004, 08:17 AM
comp comp is offline
FIRE HAZARD!!!!!!!!!! check to see if that cyl. has ,, spark(carefully),
has compresson, plug fouled?
Old 01-31-2004, 02:30 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
There is no way that enough unburned fuel is in his exahust. It would just explode. I would check the carb. something is probabally wrong there
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 01-31-2004, 02:44 PM
for safety i never tell anyone "no problem/don't worry" i don't know what
the persons mech. abilitys are, better safe than sorry, old but true
Old 02-14-2004, 12:19 PM
tomminajar's Avatar
tomminajar tomminajar is offline
Re: Gas leaking out exhaust manifold?
If Gas was leaking out Exaust manifold I doubt your brother in law would be around to tell you about it-
I am guessing you have an Electronic Q-jet . 3 guesses off top of my head - ALL FROM Experience - Is there black smoke out off the tail pipe (soot) ? Check the check valve on the Charcoal Canister you might be sucking gas right out of carb- /Ground the ALDL -turn ignition on- You should hear a rapid Clicking from the top of carb-if not the mixture controll solinoid is stuck- /
Is it hard to start first thing in morning ? Allmost all Q-jets leak after a few decades from the plugs in the bottom of the float bowl flooding the intake w/gas and emptying the float bowl- And don't forget to see if the float is stuck - If you find someone old enough to know what he's doing he can fix the q-jet (rebuild it in a hour) Don't go buy one fro the junk yard if you can find one- Rebuild the on you have
Good Luck , Tommy
Old 02-15-2004, 09:29 PM
Well my b-i-l is wtill alive and it was leaking out the exhaust manifold. Bought a carb kit and that took care of the prob.
liquid fuel leaking from exhaust manifold SoullessNihilist Blazer 9 11-15-2013 12:47 PM
93 trans am dies when given gas red hot exhaust manifolds 9_trans_am_3 Firebird Discussions 4 07-01-2009 06:52 PM
gas leaking out exhaust pipes cm3802 Blazer 4 01-11-2006 10:24 PM
Gas leaking out exhaust manifold? txcougar LeSabre 1 10-09-2004 08:37 PM
Gas leaking out exhaust manifold? txcougar General Discussion 3 02-24-2004 06:36 PM
