Go Back   Automotive Forums Car Chat > Pontiac > General Discussion
Old 01-31-2004, 01:22 AM
txcougar txcougar is offline
Gas leaking out exhaust manifold?
I hope you guys can help us out. My brother in law has an 83 Buick Lesabre with a 307. He claims iIt appears that gasoline is somehow leaking out the exhaust manifold and it has been terrible on gas mileage since he bought it a couple of weeks ago. He's also smelled gas coming from the engine compartment at times. It seems to be running okay other than this leaking gas and it only seems to leak when he first starts the engine? Hope someone can help.
Old 02-14-2004, 12:12 PM
tomminajar's Avatar
tomminajar tomminajar is offline
Re: Gas leaking out exhaust manifold?
If Gas was leaking out Exaust manifold I doubt your brother in law would be around to tell you about it-
I am guessing you have an Electronic Q-jet . 3 guesses off top of my head - ALL FROM Experience - Is there black smoke out off the tail pipe (soot) ? Check the check valve on the Charcoal Canister you might be sucking gas right out of carb- /Ground the ALDL -turn ignition on- You should hear a rapid Clicking from the top of carb-if not the mixture controll solinoid is stuck- /
Is it hard to start first thing in morning ? Allmost all Q-jets leak after a few decades from the plugs in the bottom of the float bowl flooding the intake w/gas and emptying the float bowl- And don't forget to see if the float is stuck - If you find someone old enough to know what he's doing he can fix the q-jet (rebuild it in a hour) Don't go buy one fro the junk yard if you can find one- Rebuild the on you have
Good Luck , Tommy
Old 02-15-2004, 02:34 PM
JOEROC JOEROC is offline
Send a message via AIM to JOEROC Send a message via Yahoo to JOEROC
sounds like tommy is on to something. its a comin problem with the Q jet. the only thing he didnt mention is that Q-jet = Q-junk, hahaha.
Old 02-24-2004, 06:36 PM
neves neves is offline
to help you out >>> there is no fuel in the exhaust manifold to leak out. this is just impossible if the engine is running. you might be in the right area to spot a close by fuel leak. these other guys are also correct in saying that the canister check valve could be defective. hint: check the simple things first. they're usually what is wrong
liquid fuel leaking from exhaust manifold SoullessNihilist Blazer 9 11-15-2013 12:47 PM
93 trans am dies when given gas red hot exhaust manifolds 9_trans_am_3 Firebird Discussions 4 07-01-2009 06:52 PM
gas leaking out exhaust pipes cm3802 Blazer 4 01-11-2006 10:24 PM
Gas leaking out exhaust manifold? txcougar LeSabre 1 10-09-2004 08:37 PM
Gas leaking out exhaust manifold? txcougar General Discussion 5 02-15-2004 09:29 PM
