Old 01-30-2004, 11:23 PM
jimbojones jimbojones is offline
cherokee tilt steering adjustment
my tilt steering on my 89 cherokee is starting to flop around how does one tighten this up ?>
Old 01-31-2004, 08:31 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Its time to replace the steering column. You should be able to find a good one from a wrecking yard.
You can take it apart, and fix, if its just the spring which holds the adjustment lever in place. However, its quicker to juast swap in another one.
Old 01-31-2004, 02:17 PM
GunnyJeep GunnyJeep is offline
this is a common problem with the tilt steering - there are 3 torq tip screws that work loose over time (when I finally got around to fixing mine only 1 screw was still treaded), you have to take the steering wheel off and pull the turn signal assembly aside then you can just barely see the screws - I used a 12" 1/4" dr extension to reach mine instead of pulling everything apart that is normally advised.
this picture is of a chevy column but it is almost the same
here is a good write up on fixing this problem
http://www.ifsja.org/tech/steering/column.shtml
and here (where above picture came from)
http://www.necoa.org/article95.html
good luck
gunny
1987 XJ - too many mods to list
1988 GMC Suburban 6.2 Diesel 4x4
1965 Thunderbird
Old 01-31-2004, 10:20 PM
Lightbulb
thanks for the assist i have it all sorted out just a loose nut . just like the one behind the wheel
Old 01-31-2004, 10:22 PM
Re: cherokee tilt steering adjustment
oh yes here was the 3 torx head screws and BEHIND them ther was the 2 torx head bolts there were loose
Old 02-01-2004, 07:03 PM
MagicRat's Avatar
I changed my column for nothing.
Live and learn.
Thank you for the tip.
Tilt steering wheel? davez525 5 Series 1 09-12-2004 12:28 AM
1989 Corsica Tilt Steering Wheel Removal HannabilRox Corsica 2 09-11-2004 08:55 AM
Tilt Steering on an E32? bigbimmerfan 7 Series 2 07-07-2004 10:24 AM
Tilt Steering Wheel Modification Zanark 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 04-24-2004 10:36 PM
tilt steering column 1993 Ford Van maaron General Discussion 0 10-25-2003 09:46 AM
