Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 10-25-2003, 09:46 AM
maaron maaron is offline
tilt steering column 1993 Ford Van
I am seperating the steering column at the pivot point to put new bushings in the upper halh of the column. However, I am not smart enough to fiqure out how to disconnnect the ignition actuator rod from either half of the column. I have the lock cylinder out but the actuator is still connect to the gear that the lock cylinder turns. In the lower half of the column the piece that actually move the ignition switch, seems all contained and I can't get that out either? I'm sure there is something simple that I am overlooking. Please help.
Thanks. maaron
Tilt-Steering column has a little play in it. NATE7 Century 0 09-08-2008 02:01 PM
NEEDED Steering Column 1993 Ford f-450 sewally F Series 2 11-12-2006 06:25 PM
wobbly tilt steering column with floor shifter guahanx Sierra 3 10-20-2004 07:39 AM
Mazda Millenia auto tilt steering column hartge1978 Millenia/Xedos 9 3 10-05-2004 04:26 PM
