95 blazer, OBD-II scantools not reading
This is the #^@#@%@ CPI engine. Nice HP, but that's it.
It is supposed to be OBD-II compliant, but have wasted money on two different scantools (Stinger and a PC-interface), and neither can read codes (stinger can erase codes). GM dealer COULD READ IT, so my onboard interface is working. HINTS? IDEAS? Thanks. Dave.- |
Re: 95 blazer, OBD-II scantools not reading
95 was the "BASTARD" year during the switch to OBD2 diagnostics...Your vehicle is equipped with the 16 pin OBD2 DLC, but the computer and operating system is still OBD1
You can sometimes "trick" the code readers into reading by changing the year to 96...
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
good save
that could have been a postal shooting hadn't got that info, is it- all, most, some,,, 95's |
Yes and no.... Early 95 s10 blazers used ODBI.5, later year 95's used ODBII... The best way to tell is to look at the ECM/PCM. If it's under the hood, it's ODBII, if it's under the dash it's ODBI.5. Also ODBI.5 use a top post mounted distributor system, while ODBII uses the side post mounted distributor. The ODBI.5 uses the ODBII connector unfortunatly, so what you need is the adapter that allows a ODBI scanner to be used with an ODBII plug...
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
