Old 03-04-2004, 11:02 AM
MGoBlue102 MGoBlue102 is offline
OBD II reading for Emissions problem bay 1 ???
I have a 1996 Blazer (W code). Occasionally (usually when I drive a long distance at 60mph or more) my Check Engine Light comes on. I had autozone run the OBD II test to get the reading "low emissions, bay 1" . They reset it and it comes back every once in a while with the same error. Can anyone tell me what bay 1 might mean? I thought it may be the 1st Oxygen sensor of the many that are on this thing. I heard GM can do a better test than Autozone but its 80 bucks too. Usually I just remove the two 20amp fuses to the guages for a minute or two to reset this myself now instead of having Autozone do it. I dont want to guess at which oxygen sensor it may be (if it is that) since each is about 50 bucks. Can anyone give me some info???
Old 03-05-2004, 06:43 PM
Jeremy-WI Jeremy-WI is offline
Re: OBD II reading for Emissions problem bay 1 ???
Are you sure it wasn't TWC low efficiency bank 1, if so it might mean you need a new catalytic
Old 03-05-2004, 07:15 PM
amac209 amac209 is offline
Send a message via MSN to amac209
do you have a number for the code??? if it comes back get the code number.
Old 03-08-2004, 02:13 PM
vinnie97 vinnie97 is offline
try cleaning your O2 sensors with a o2 safe injector cleaner or something. i cant remember the code i got but it ended up being the 1st O2 sensor. It was way darker the the 2nd.
Old 03-08-2004, 03:05 PM
I will get the code, I cannot remember the number it gave me. I did put a new cat on around a year and a half ago. I did have some issues with the weld on it but fixed that one.
emissions test set up for wrong engine puterhead Engineering/ Technical 0 10-08-2010 06:22 PM
1995 Bonnevillle OBD reading johershey Bonneville 11 02-28-2008 03:15 PM
FOR THE SF BAY AREA PEEPS...alignment question bennybenster '88 - '91 Civic | CRX | Wagon | Shuttlee 1 05-21-2004 06:18 PM
Any 240s for sale in Bay Area? clamdestine 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 09-17-2003 11:14 PM
Squieling Problem for the engine bay. JimsCivicEX '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 05-21-2002 02:41 AM
